Results 1 to 4 of 4
Thread: Toyota Yaris
    mkabrar's Avatar
    Jun 2006
    39
    Default Toyota Yaris
    Asalamo alaikum hw r u alll???? need to know that can i use the auto parts (like ABS, Fuel Pumps etc) of Toyota ECHO in Toyota YARIS?
    waiting for the reply
    syed_hassan's Avatar
    Apr 2005
    50
    77
    u can, provided same CC
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    As syed_hassan said, youcan indeed swap parts around as long as the cars are of the same CC since they are essentially the same car.
    Ecco/Platz is an extended platform of a Yaris/Vitz
    szuberi's Avatar
    Mar 2005
    Toronto
    41
    3,576
    not all parts are dependent on the CC or displacement b/w two cars. Yaris and echo are the same cars essentially so most parts should be swappable. you can easily swap alot of parts from...for e.g. a 1.3 sedan into a 1.0 four door hatchy.
    it all depends upon what type of part you want to swap? wheels, brake system, suspension might be straightforward but ABS is technical as it involves sensors / ecu.
    so what exactly u wanna swap?
    I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it..and so restriction of free thought and free speech is the most dangerous of all subversions.
