Results 1 to 9 of 9
Thread: Engine Oil Grade for Vitz 2006 KPS 90 Engine
    vitz_2006's Avatar
    Jul 2012
    108
    2 Post(s)
    Default Engine Oil Grade for Vitz 2006 KPS 90 Engine
    Can anyone confirm the Toyota recommeded oil grade for Vitz 2006 KPS-90 1000 cc engine(e.g 5W-40 or 10W-30 or 10W-40 etc)
    Secondly can "fully-synthetic" oil be used on 50000 km old Vitz 2006 KPS-90 engine or should "semi-synthetic" or "mineral" oil be used in that much old engine.Please suggest
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    what type of oil are you using at the moment ???
    I have seen one Owners' manual for Vitz (2nd generation) which recommended 5W-30.
    vitz_2006's Avatar
    Jul 2012
    108
    2 Post(s)
    I am using 10W-30 Havoline formula right now .Its good however its only API SL while latest oil grade is API SN(two grades superior than Havoline formula) .But as you said manual recommends 5W-30 for Vitz 2006.....That means I need to change!!!!
    What is the best 5W-30 oil choice as neither Havoline nor Shell has this "5W" grade oil with 30 viscoity?
    ZIC ,Mobil and rest are too risky because of:
    1). Their fakes in the market(which 'might' be avoided by buying them from the authorized distributor and 'hoping' its the original one)
    2). Original ones with ever degrading quality by distributors in Pakistan(which cannot be avoided)
    Ravager's Avatar
    Oct 2007
    28
    2,030
    46 Post(s)
    4 Thread(s)
    i use total 5w30 singapore made. excellent oil. fully synthetic.. costs around 2600.
    gives me good mileage on my 1300cc 2nz-fe.
    drive is smooth aswel
    Drugs cause amnesia, and other things I can't remember
    5555's Avatar
    May 2009
    25
    688
    3 Post(s)
    recommended grade is 5w30 go for shell helix ultra or helix plus both are 5w30
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    In addition to the above-mentioned suggestions, Mobil-1 Super Synthetic 5W-30 also fulfills the criteria. In fact exceeds it by far.
    Anyways whatever the brand is, 5W-30 being a thinner oil will give you peace of mind in cold starts in the winter mornings.
    vitz_2006's Avatar
    Jul 2012
    108
    2 Post(s)
    What if I use 0W-30 instead of 5W-30. Will it be ok for my engine or may create some problems as 0W-30 is a bit thinner than 5W-30 in winter?
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    If you live in a permafrost region such as Siberia or Canadian north where all year long temperature remains sub-zero, then its highly recommended that you go for 0W.
    Else, go with the manufacturer recommendation (5W) for optimum economy and longevity of engine life. Using OW in Lahore might make your engine slightly noisy.
    AmmarSaleem's Avatar
    Aug 2012
    283
    go 5-30 in winters and 10-40 for summers and go to filter house dha at least you'll get aik number oil do check the consistency of oil every 500 kms when you rub a drop of oil between your fingers it should be sticky
