Results 1 to 7 of 7
Thread: Right Advancer and Emulator for Vitz
    mnaeem's Avatar
    Nov 2005
    43
    39
    Default Right Advancer and Emulator for Vitz
    Which CNG kit, advancer and emulator work best in Vitz?
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Zetronic
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    testdriver is right
    Keep a cool head and wear seatbelts!
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    get lendirenxo electronic kit with m96 switching....
    well if considering lendirenzo then any grip to grip emulator..... and advancer model is stap 100/2..........
    basically the real problem comes with advancer... i will suggest you to go for lendirenzo stap100/2 instead of zeltronic and others... caz i first had zeltronic for 2nz-fe(gli engine) which has almost the same electronics to that of 1sz-fe(vitz engine), and it wasent that good, and when i converted to landirenzo the performance was much better....
    i still have the zeltronic advancer lying in my store...lolz
    its all about power to weight ratio...
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    @guncha
    Cha gaye hain aap!
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @Ghuncha
    May be you have had a bad experience, but, Not every person can install and cofigure these gadgets. I have seen a number people fed-up with their landi-renzo setup..... If you want, I can quote you the website where you can find the detailed instructions about the Zetronic's configuration:
    http://zetronica.com/
    Another most important thing is that I have Landirenzo Advancer coupled with the Zetronic Emulator and they are working perfect.....It is the tag work been done and internally logic is the same. Even they use NEC and Siemens chips......So I am not denying your statement since everything internally is almost same
    Adnan's
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    489 Post(s)
    19 Thread(s)
    Hello!
    my friedn got 2000 VItz......he fries up Two advancer and emulator :p.........
    they are of Lovato with Advancer an Emulator in one........
    now he got some NE????tec....
    it still shows check light some times sometimes it works perferct.....
    i think Zetronic and Landirenzo are best to go for....anywayz.......are Advancer and Emulator are 2 in 1...?
    means advancer and emulator both in one box?.....
    plz tell me bcz friend was not felling taste of 1SZ-FE....pick was damn slow.....and ride was not as good as it has to be.......he also got his 2 injectors useless using that advancers....
    Thanxxx
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
