Results 1 to 10 of 10
Thread: vitz service
    azkaar's Avatar
    May 2006
    Kamra
    39
    Default vitz service
    i have recently bought toyota vitz 1.0L . can anybody guide me about the servicing of this car as far as different fluids and routine inspections are concerned.
    szuberi's Avatar
    Mar 2005
    Toronto
    41
    3,576
    u can perhaps get a service schedule from the closes toyota dealership? or contact storm on the forum..he recently bought the same car...he might be able to give u a few tips.
    I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it..and so restriction of free thought and free speech is the most dangerous of all subversions.
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Hello!
    1st have a eye on Brake Oil,Power Steering Oil,Transmission oil(if auto) or Hyd Clutch Oil(If manual)...and yeah replace engine oil as soon as possible......
    brake,power and tranny oil are way low on their mark...so fill then till their mark and also check transmission oil....if needed replace both oil and filter as thats better to replace engine oil and tranny oil(auto)....
    after that...get the car serviced from inside(interior)....
    don't do anything on engine room...no water nothing.....just some low pressure air from a distance..or it can harm any sensor or wire...........
    get tires air pressure checked and maintain them to 28 front 30 rear.....
    get the car serviced from the best servicer as he knows better how to service Efi cars...
    Thanxx
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    I had the following done at toyota:
    A.T.F Oil (Type TIV) 1380
    Air Filter 1250
    Brake Fluid/oil 345
    Brake Fluid/oil change (labour) 100
    Brake Service Labour 500
    Engine Oil & Filter Labour 100
    Engine Oil (4 litres) TMO 2000 700
    Engine Tune-up (Fuel & Air Filter) Labour 500
    Fuel Filter 2100
    General Checkup Labour 300
    Oil Filter 450
    Power steering oil & Transmission oil Labour 300
    Radiator (LL Coolant) 890
    V-belt (pending)
    V-belt replacement labour (pending)
    New battery (pending)
    now all i have to do is check the oil from time to time and fill it up with fuel. Complete peace of mind.
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    @SER_GTR
    According to the users manual
    OEM sized tyres: - inflation pressure
    155/80R13 ff (1SZ-FE) 220 kPa or 2.2 kg/cm2
    155/80R13 4wd (2NZ-FE) 200 kPa or 2.0 kg/cm2
    155/80R13 ff (2SZ-FE) 240 kPa or 2.4 kg/cm2
    175/65R14 ff (all) 220 kPa or 2.2 kg/cm2
    175/65R14 4wd (all)200 kPa or 2.0 kg/cm2
    185/55R15 (all) 210 kPa or 2.1 kg/cm2 (front) & 200kPa or 2.0 kg/cm2 (rear)
    Spare tyres: - inflation pressure
    T115/70D14 420kPa or 4.2 kg/cm2
    T105/70D16 420kPa or 4.2 kg/cm2
    Radeon9200's Avatar
    May 2006
    35
    16
    Storm - why is it necessary to change V-belt? You'd once mentioned about some hardware and software that is used to reverse the odo meter of vitz. Just curious what is it and where can this be obtained.
    Thanks
    AkbarGr8's Avatar
    Oct 2004
    32
    5,972
    8 Post(s)
    @radeon9200(does the card even have Dx8 capabilities? )
    letting you know before storm himself replies, he's not gonna give you the info which you have enquired about, so you should try asking elsewhere
    Bees waal 4 life
    Radeon9200's Avatar
    May 2006
    35
    16
    My dear Akbar - have you heard a little about overclocking. You would not try to ridicule radeon if you knew its overclocking potential. Anyways its not the gun but man behind the gun.
    Storm will not disappoint us, I know.
    AkbarGr8's Avatar
    Oct 2004
    32
    5,972
    8 Post(s)
    hahahahah, no actually i admire radeons, but not particularly that model. i have a 9800pro mysef, with vga silencer cooler on it.
    any ways, i guess you're waiting for a response from storm himself (6)
    Bees waal 4 life
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    @Radeon9200
    I'd love to share the info but i honestly can't since it violates every fibre of me on an ethics ground.
    @AkbarGr8
    LOL!! you know me too well bro!
