Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Like Tree8Likes
Thread: Vitz's consumption?
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    Question Vitz's consumption?
    What should the petrol consumption of a 2002 manual Vitz be? The odometre has 125000 km reading but knowing the mentality of reversing, m sure it's much more. The car has NO problems whatsoever. I just want to know the mileage it ought to cover. No CNG installed.
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    Doesn't anyone own a Vitz here?
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    expect it to give you 15 kmpl in city and 23 kmpl on highway at speed of 100 kmph.
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    i am currently getting 18 plus kmpl from platz 2001 on last tank it gave 18.7 kmpl. between pindi and islamabad during rush hours. the car is 138k km driven. and has a 55kg cng cylinder in the boot. and yes i hypermile a little bit.
    car has a manual transmission. and i drive with AC on even in winters.
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    ^ and if you dont believe these figures i can prove these on the vitz you ll buy. and nothing is abnormal about my driving.
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    Well well well...........the Vitz m talking about covers only 420 km in a single tank. Assuming that the car has a fourty two litre tank, that means just 10 km/l. What is the solution?
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    I am not sure how well maintained is your car. do a tuneup. throttle body, adjust tappets (which i think cannot be done in the regular way), get the plugs cleaned / replaced.
    get the MAF sensor checked. it malfunctioned once in our case. and was replaced with a second hand one at 20% of the cost of new one. (600 rs. i guess)
    our platz is maintained by toyota rawal n i supervise everythng they do. satisfied client.
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    I have noted everything and hope to sort it out over the weekend Inshallah. Is your car's catalytic convertor still in tact? This one's is.
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    no its been taken out.
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    What do you recommend to do about this Vitz's? Follow your initial instructions and then decide about the converter, no? Or should that be chucked out as well? There was a topic where someone had recommended a workshop in I-9 to get that issue fixed. Your opinion?
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    do it as a last resort. someone with a reborn here on pakwheels do the frequent cleaning of the convertor by dismantling the exhaust pipe and brushing / air blowing. i think you should try to do the same. once removed your vitz be wont the same but after an year or two you ll forget wat it was like with the convertor.
    in my case removing the convertor slightly lowered the consumption and made the engine little bit noisy.
    you should add the following to the list:
    1) checking / replacement of fuel filter. the one that goes below the rear seats
    2) get a bottle of liqui moly injector cleaner and put it in your fuel tank and go for a long drive.
  12. #12
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    Retaliator, many many thanks for your guidelines. I'd appreciate if you could message me your number at 03215016157 so i could go to your mechanics and you guide them with all this directly.
  13. #13
    060276's Avatar
    May 2009
    27
    1,859
    43 Post(s)
    @vajih/...hy i have a manual vitz 2000 model only petrol driven....124000 km driven , not reversed .. bought 3 months ago....its giving me 15-16KM/l local islamabad checked serveral times ....and 18 KM/l on long....i just changed oil helix hx4 -10w-20 -oilfilter-air filter.......havent done general tunning yet ...give me a buzz at 0333-5618506 , if u want..
    btw in normal circumstances and in islamabad city driving ,it should give you atleast 15-16 km/l
    Umer Siddiqui ... Inline Six .... ** 2JZ-GE **
  14. #14
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    Thank you for your number. I'll definitely get in touch with you once the car is available. However, the previous owner must have worked on the car already. I find it difficult for a decade old vehicle to be good as new.
  15. #15
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    Sorry i couldnt reply in time. had a busy weekend. hope your problem is resolved. i rely on toyota rawal ppl for all the work. the catalytic convertor was done by Akhtar Mechanic who outsourced it. his number 0300513204. hes can be found in the street to the left of Odeon Cinema in Pindi. next to MH. but the car has been mostly maintained thru Toyota Rawal.
  16. #16
    usman72's Avatar
    Dec 2012
    23
    Default mitsubishi ek wagon
    I purchase a ek wagon. I am much worried..it is 50,000 km driven.i full its tank and it gives me just 320 km in 30 ltr..i am very disapointed..i was hearing the voices that it will gives the mileage 22 -25 km/ltr but not....what is the problem
  17. #17
    tanoli16's Avatar
    Jul 2014
    63
    contact me: 0344-9518818, i tell U the real story wht to do, I have same problem, now Vitz tank shows 702 KM after that....
  18. #18
    faheem205's Avatar
    Oct 2012
    Rawalpindi
    18
    2 Post(s)
    @ tanoli16 it would be great if you discuss the solutions here as it will benefit others too.
  19. #19
    tanoli16's Avatar
    Jul 2014
    63
    Post vitz-2011 re-set ECU....
    I have recently purchased Vitz-2011 new shape, after that Full the fuel tank.It shows 9.5 KM/L and over all 585 KM of tank capacity that can be run.
    This 9.5 KM/L increased slowly up to 11.2KM/L after 300 KM used. I was vvvv upset and checked the vehicle from enercon wks center G-10 (near Islamabad H.Court) he has checked and said its 100% OK, but not satisfied and after used of 140KM petrol used about 12 liter so consumption come 11.66 KM/l.
    again i go to another wks near Daewoo Naseerabad, Ali automobile, he checked with carman scanner. and told that all sensors are OK, no fault. but the problem was SAME.
    after that i have friend that has same car, he told me about RE-Set of computer (ECU) that is done by as.
    1) Remove the Negative terminal of Battery for 5-minute.
    2) again Tight the -ve terminal.
    3) switch ON the car.
    4) The ECU reset and for 20 second the engine was unstable, but after that become STABLE.
    5) Drive the car for 30-minute on normal road as well as Motorway, for observing pakistani road conditions as well as Pak peterol vs engine conditions.
    6) The dasboard computer that does not go beyond 11.2, goes up to 19KM/L and that is confirmed.
    7) Now the car is so light and changing Gear (AT) quickly.
    Now it shows 702 KM instead of 345KM, and duly verified.
    I am so happy and telling it to all friends the reality.....that is safe .
    Dont open/clean the Throttle Body..................untill the scanner shows 0-fault.
    Be aware of it.
    Regards.
    Naeem
    NESCOM
  20. #20
    usama1's Avatar
    Sep 2005
    37
    1,460
    Quote Originally Posted by tanoli16 View Post
    Be aware of it.
    Regards.
    Naeem
    NESCOM
    Great...congrats your problem solved...
    Sent from my LG-F160 SKL using PW Forums mobile app
Tags for this Thread
