I'll try to send u a link after some search etc., as I have soft copy of Passo only at the moment...
What can be the price of meter with RPM for Vitz 2009 model 1KR and is it plug n lay or something to do with wiring ?
Can any one please clarify?Can we install cruise control in imported Vitz current models?
I do lot of travelling on motorway, it will create ease for me, if possible
naeem.ikram@hotmail.com
Highly obliged
AoaPlz recommend the engine oil....I have 07 vitz with 120k on the odometer. ...Currently I m using toyota engine oil (tin pack) 10W30....
Oil is fine & you can use 5w-20 for better economy you should thing about 100k plus maintenance like1)check pcv valve2)valve clearance etc
Problem is non availability of toyota oil at my place..... I m in quetta.... so pl suggest some other brand..... I got pcv valve checked, fuel injectors serviced, throttle body serviced a few days ago from magic motors....
I want to get a decent navigation for my Vitz, its 2013 model.
Can someone please suggest a decent system with phone connectivity,
Also is it possible to get steering controls.
Please mention price, I am located in Karachi.
Many thanks.
If u want navigation and phone connectivity then get an android based double din dvd player cost rnd 25000 i guess , if u want a dvd player with good sound quality and phone conectivity then buy a pioneer double din dvd player
Sent from my iPod touch using PW Forums
Where the pcv valve located in 2006 Vitz (1000cc, 3 cylinder )? Mechanics do not know about it.
Anyone ?
Brother i need Vitz 2000-2001,02 and my budget is maximum 7 lac, plz can anybody help me in this regard. I i am from peshawar. Thanks alot
This seems like a number printed on the meter panel that reflects external light. I do have same car and this is mostly visible during late evening when sun is low.
Sent from my Galaxy Nexus using Tapatalk
Still waiting for suggestions regarding engine oil for vitz 2007.... wid 120k on odometer. ... Currently using Toyota Tin pack 10w30.... but its nt available at my place and car has already done 5000 km including return trip from Quetta to Lahore....
My 07 has clocked 96k and I'm using Shell Ultra 5-40. You can use that if you know your engine isnt consuming oil or use the semi-synthatic HX7 from shell. I've found the sell oils to work great. Most members also use Mobil1 and LM oils but I've never had a problem with any of the shell oils that are used in every car/jeep at our house.
There is one available (orange illumination) for 4500 in Shoba. I had the panel tested and everything worked on it. Plus no broken clips or cracked glass too.
plug n play ?
Cruise control install 2009 Yaris 3 door - Toyota Yaris Forums - Ultimate Yaris Enthusiast Site
There are a few more detailed thread too showing the wiring if you do a search in google. Its a simple DIY, been done here on PW aswell in a few civics.
Thanks alot sir
NP
Yup. As far as I know, @uashah007 has done the switch to the updated meter.
