Page 594 of 605 FirstFirst ... 94494544584592593594595596604 ... LastLast
Results 11,861 to 11,880 of 12083
Like Tree1572Likes
Thread: Toyota Vitz Owners/Fan Club
    obz3ed's Avatar
    Jun 2005
    Dubai
    40
    72
    Default Toyota Vitz Owners/Fan Club
    The purpose of this post is to gauge the interest in forming a Toyota Vitz Owners Club in different cities of Pakistan. As we all know that Vitz has become quite popular in the last year or so. More and more people are buying it or are interested to know more about it. The purpose of the club would be to share technical / operational information regarding the car. As well as help fellow members with different issues regarding the everyday running of the car. There would be regular meets and get together as well as cruises. The criteria to join the club would be to own a Vitz and a desire to help and share information with fellow members. I myself am based in Karachi, so I can take the lead in taking off this project here. Other can do the similar thing in their respective cities. If there is enough interest, a formal charter / by-laws would be issued with club rules and regulation as well as its mission statement. The club would operate under the same rules & conditions as other international car clubs. To take this project off the ground, I believe 10 people in each city would be the minimum requirement. If anyone from Karachi is interested in being a part of this club, please email me at danyal1@hotmail.com. Pakwheelers from other cities can share their email addresses under this post if they are willing to take the lead for their respective cities. I hope to this see become a success someday and a model for other to follow. LETS MAKE IT HAPPEN GUYS!!!
    Redundancy: A Politician with an airbag in his car
  2. #11861
    muzammil100's Avatar
    May 2015
    Quote Originally Posted by racerali View Post
    Bro you can attach any Elm 327 device
    My friend Has vitz 2013 and cheap elm 327 can do good in your case
    sensor data ,error code
    I dont have one. The mechanics I showed to tried to scan using their bluetooth device but it kept failing.
  3. #11862
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
Size:  141.0 KBName:  1473525663565.jpg
  4. #11863
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Purchased above Pioneer player for my Ride.. 😊
    Found it awesome
    Tomorrow will install it
    Sent from my GT-I9192 using PW Forums mobile app
  5. #11864
    tariqjamil705's Avatar
    May 2014
    34
    71
    Quote Originally Posted by changwani54 View Post
    Got some maintenance work done on my Vitz 2012 last week.
    Starting with CVT oil change.
    For gear oil aka CVT oil change plz try to read a forum on CVT oil change for Toyota Belta Vitz Passo etc and try to find @Xulfiqar bhai's posts in that forum.
    Either you can go for opening the chamber approach or draining it via drain hole approach.
    I went for changing oil via drain hole approach. Allen key which our common mechanics call "L key" is used to open it. After opening that nut or screw, same Allen key is used to remove the tube that is inside the chamber. Here is the tricky part, most of the mechanics including ones at 3S do know how to take that tube out but they prefer not to, as changing the oil via that bolt doesn't pay well. Usually they try convincing you that opening the chamber is must. Tell the retards that engineers who made the car are way better than them and they didn't put the drain hole and inside tube just to check oil level.
    To be sure exact amount of fluid that comes out, ask the oil guy to collect it and measure the quantity of drained oil. Put back same amount of oil.
    On the other hand if that's not feasible then after draining the oil put back the plastic tube into the nut hole. Do not put the screw or nut back in its place, just the tube. Put the oil via nut hole in upper part of chamber (don't remember which one is it but oil guys usually know it). When oil starts dripping from the hole, wait for it to stop. Start the car and put it in D. Again pour oil till it starts dripping again, it will roughly take 200 to 300 ml of additional oil. Alternatively you can put the screw back after the oil had initially started dripping and add roughly 200 to 250 ml of extra oil. That's it.
    No need of anything else. Car will take back total of 2 to 2.5 L of CVT oil, nearly exactly the amount that was drained.
    P.S. Plz don't be confused when u find someone saying it takes total of 6 or 7L of CVT oil, that's only done when you build the transmission from zero. You can't drain the whole oil, just 2 to 2.5 L of those 6 or 7 L are drained and that's what u put back in.
    Also opening the chamber technique would require roughly 3.5 to 3.8 L of oil.
    Excellent dear,
    it is realy in detail information. I have Toyota Vitz 2013, with more than 39000 odo. I am going for its 1st oil change in Pakistan. Further i also want to change its gear oil(cvt). Should i go to some Toyota 3S for engine transmission oil(mobeloil)+gear oil (cvt) change or any other good recommendation in Lahore. What can be expected cost for engine oil change(Oil price+oil filter + and air filter price+services). What can be the expected cost for gear oil change (oil price+services). Please inform. I am not from Lahore and will be coming to Lahore just after eid so please reply early. Recommendations from other respected members are also welcome.
  6. #11865
    chinyoti's Avatar
    Sep 2005
    27
    11,964
    5
    108 Post(s)
    5 Thread(s)
    Quote Originally Posted by walls View Post
    Found it awesome
    How much did you get it for? I need to change mine aswell.
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
  7. #11866
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Its in 12,600
    Made in Thailand
  8. #11867
    saadkhan35's Avatar
    Jul 2014
    44
    2 Post(s)
    guys I am getting a one time springy noise when ever I drive away my car after its been parked for an hour or two. has anybody else faced this? sound comes just once that's it.
    discussed this with mechanics they say its suspension noise, nothing to worry about.
  9. #11868
    xubair.ashraf's Avatar
    Oct 2012
    231
    6 Post(s)
    Suggestions needed for head unit for Vitz 2012. Currently it has stock one which isn't of much use. Must have aux and USB options. Navigation not necessary. Plz give some suggestions.
    Sent from my QTab Q1000 using PW Forums mobile app
    Driving safe is better than not being able to drive..
  10. #11869
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Quote Originally Posted by xubair.ashraf View Post
    After a lot research I have purchased above player that I shared
    In less price I was able to install china dvd with back camera.. 7000 to 8500 only. But that thing is not quality sound. So I got this Pioneer brand with mixtrax option. Awsome player.
    Options including usb, cd, and aux
    But if you have good budget then go for good brand dvd player.. that will cost 35k plus
  11. #11870
    Oct 2012
    231
    6 Post(s)
    Thanks for the response. Currently my budget is same. Will check this one out. Can u share from where I bought it
  12. #11871
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    I have purchased from HALL Road
    MRM Traders.
    You can see more options too.. but don't go for low quality Chinese one.. you can also go for single din player..
  13. #11872
    Oct 2012
    231
    6 Post(s)
    MRM Traders.
    Ok. . So have u got that installed? Can u share pics after installation?
    Sent from my SM-N9005 using PW Forums mobile app
  14. #11873
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Yes I will install it by today or after eid.. will share pics
  15. #11874
    Nabeel_Ali's Avatar
    Feb 2010
    24
    3,509
    108 Post(s)
    Quote Originally Posted by saadkhan35 View Post
    This comes from every vitz.
    Sent from my SM-N920C using Tapatalk
  16. #11875
    saadkhan35's Avatar
    Jul 2014
    44
    2 Post(s)
    Quote Originally Posted by Nabeel_Ali View Post
    so it comes in both of your cars? i remember you have 3rd Gen and 2nd Gen as well.
  17. #11876
    Nabeel_Ali's Avatar
    Feb 2010
    24
    3,509
    108 Post(s)
    Yes from both.
  18. #11877
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
Size:  59.8 KBName:  1473781153458.jpg
Size:  29.8 KBName:  1473781342741.jpg
  19. #11878
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    Its in 12,600
    Made in Thailand
    i am getting u555i same model for 9K in ISB. please recheck the price.
  20. #11879
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Check Ur handbrake , get rear brake service done , mostly stuck handbrake drum
    Sent from my ALE-L21 using PW Forums mobile app
  21. #11880
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Quote Originally Posted by Thinking View Post
    Wow
    Big difference..
    Go for it..
    I have paid more at Lahore
    Just check warranty etc and made by before purchasing.
