Results 1 to 5 of 5
Thread: Vitz transmission changes goes neutral during drive
    talha.vitz's Avatar
    Dec 2012
    30
    10
    Exclamation Vitz transmission changes goes neutral during drive
    AOA
    Dear fellows
    I have a vitz 2003 model. When i drive after some time the car goes neutral and on acceleration there is increase in RPM but no thrust. then i have change the gear randomly from D to 2 or neutral and revert back to D to pick the gear. Can anyone tell me whats the problem here. I also checked the O. D. button its not the cause
    Thanks
    ngen's Avatar
    Oct 2008
    38
    166
    either you have put the wrong gear oil or your gearbox needs repair.
    john0995's Avatar
    Jun 2008
    Hari pur
    1,532
    17 Post(s)
    Manual transmission is good
    CoMmiNg SoOoOoOoOoOoOoOoOn
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    seems electrical fault
    Hanjiii Kaa Storeey Eehh !
    talha.vitz's Avatar
    Dec 2012
    30
    10
    Yeah it was electrical fault! thnks
