Results 1 to 2 of 2
Thread: Need help - Planning to swap vitz 2005 1.0L engine with 3.1l
    thepretender's Avatar
    Dec 2007
    78
    Default Need help - Planning to swap vitz 2005 1.0L engine with 3.1l
    Hi All,
    I am planning to swap my vitz 2005 1.0l engine with 1.3l engine.
    Can someone please guide me a place where I can get the engine easily? How much will it a 1.3l engine cost? Will it fit properly in the current space of the engine? Also guide me an expert mechanic who can perform this task? Will there be any problems in the long run as I intent to use my vitz for the next 5 yrs.
    Also, will I be required to update the car documentation after the engine swap?
    ngen's Avatar
    Oct 2008
    38
    166
    Shershah is where you need to go get the engine.
    you might need modifications to the mount areas but i've seen a 2003 vitz with a corolla engine ... it does fit in the engine bay area.
    you never know how long the kabuli engine will last so there is no guarantee that it will continue to work for 5 years.
    yes you will need to get the engine number changed... make sure you get a reciept for the kabuli engine so you can submit it for engine number change.
Tags for this Thread
