Results 1 to 8 of 8
Thread: Vitz 2004 sudden brake issue
    quaidian's Avatar
    Oct 2006
    38
    329
    11 Post(s)
    Default Vitz brake issue - soft/light pedal with shoop shoop sound
    For last couple of weeks I am having a problem in my Vitz 2004 running only on petrol. The brake works fine most of the time but sometimes while driving when I press the brake pedal, it feels very light and brake doesn't respond timely like it does normally and naturally my foot presses the pedal little more and then suddenly it feels the wheels are jammed and car halts for a while and as a result I almost fall on steering. As soon as I lift my foot from pedal car resumes it motion as normal. This unusual braking hurts as it shakes your body badly for a while and a couple of times because of sudden stalling of car, the motorcycle hit car from back. I need to know what's wrong with brake system, why does it behaves abnormally sometime, any idea how to fix it?
    The frequency of happening of the said issue is increasing with passing of each day and some times the issue happens continuously for some time.
    Another thing is when I press brake pedal it gives "shoop shoop" sound not sure what does mean.
    Engineer1's Avatar
    Dec 2009
    32
    640
    check brake disks, brake leathers and Drumss,, may be it need to be polished and brake leather also needs a change...
    Drive Hard or stay Home............
    asimgujjar's Avatar
    Jan 2008
    29
    707
    4 Post(s)
    Are u aware of ABS ????
    Why depreciation factor is not applicable to Pakistani corolla ????
    quaidian's Avatar
    Oct 2006
    38
    329
    11 Post(s)
    of course I am aware of ABS :-) and I am driving the same car for almost a year and felt the mentioned problem just from last two weeks - do you mean this is normal ABS behavior, not at all :-(
    * The difference between genius and stupidity is that genius has its limits *
    shariqak1's Avatar
    Nov 2006
    983
    It looks like related to ur car's ABS sensors! Try cleaning the area may be some mud on sensors is making difficulty in proper braking. Experts will guide you better.
    Speed costs money. How fast do you want to go?
    quaidian's Avatar
    Oct 2006
    38
    329
    11 Post(s)
    There is also shoop shoop sound when I press brake pedal, does it give any idea od problem, is this related to brake booster or a sensor issue?
    quaidian's Avatar
    Oct 2006
    38
    329
    11 Post(s)
    There is also shoop shoop sound from pedal when I press brake pedal, does it give any idea od problem, is this related to brake booster or a sensor issue?
    Ehsan4808's Avatar
    Sep 2007
    34
    1,811
    7
    53 Post(s)
    Bad Brake servo might be the reason
