Results 1 to 5 of 5
Thread: Changing Engine Oil and Gear Oil for Vitz 2008
    SalmanHanif1's Avatar
    Nov 2012
    28
    34
    Default Changing Engine Oil and Gear Oil for Vitz 2008
    1. Please suggest a good mechanic near bahadurabad area in Karachi to change the engine and gear oil for Vitz 2008?
    2. Which oil is best for engine and gears?
    3. Should I change it at PSO pump near Aga Khan Hospital?
    Your corporation would be appreciated. Thanks
    Proverbial_Slang's Avatar
    May 2005
    3,906
    29 Post(s)
    Is it 1.0 or 1.3? Engine code would hep too.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
    Nov 2012
    28
    34
    Quote Originally Posted by Proverbial_Slang View Post
    Its 1.0. Engine Code 1KRFE. Transmission Axle code K410.
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    Quote Originally Posted by SalmanHanif1 View Post
    So which one you used for Engine Oil? Transmission is only Toyota's good.
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,712
    22 Post(s)
    trans oil , toyota cvt-lc 4 L
