Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Vitz Power Steering Issue [Urgent Help Required]
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    Unhappy Vitz Power Steering Issue [Urgent Help Required]
    Salam
    A friends Toyota Vitz model 2009, 2012 import is having power steering issue. The power steering turns off(steering becomes hard) sometimes when he comes to a stop at a traffic signal, then when he gives the engine some revs it again starts working.
    His car got washed first time from inside the bonet(without his knowledge maybe by brother) from a service station. There is also some water in the left side front light.
    What could be the issue and possible fix for this issue
    Waiting For replies
    EDIT:
    Just noticed something , the problem only occurs when the steering is put into full lock on either side.
    locked it 5-6 times to check and the same thing happened again and again.
    What now
    Regards
    Wasil
    Never give up, never back down, Always give a 110 percent,
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    bump.....anyone
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    23 Views and no replies , come on guys
    YasirAkram's Avatar
    Jan 2013
    Quote Originally Posted by wasilrkhan View Post
    Salam
    Waiting For replies
    Regards
    Wasil
    more details plz
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    bump...
    alikhan7's Avatar
    Mar 2005
    Multan
    33
    744
    6 Post(s)
    Seems EPS malfunctioning ask him to reset ECU
    SER_GTR's Avatar
    Nov 2005
    30
    9,736
    16
    489 Post(s)
    19 Thread(s)
    Sounds Like Some BUG With EPS.....Reset The EPS System....!!
    Might Need Scanner Attached To Do It....!!
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    Quote Originally Posted by SER_GTR View Post
    Could this be because of under bonet water service
    SER_GTR's Avatar
    Nov 2005
    30
    9,736
    16
    489 Post(s)
    19 Thread(s)
    The EPS Usually Lies Underneath Cabin ...
    Did You Feel It After Water Service???
    Water Can Get On Wrong Places Sometimes Causing It But It Can Also Be EPS System Running Into LIMP Mode....
    SER_GTR's Avatar
    Nov 2005
    30
    9,736
    16
    489 Post(s)
    19 Thread(s)
    @Xulfiqar can answer it better...
    autophile's Avatar
    Sep 2004
    13,578
    20
    6
    405 Post(s)
    Please post your problem in Vitz owners or fans thread
    Be polite on the road. Always give way to others, particularly ambulances and pedestrians.
  12. #12
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    Yes , before washing it was fine.
    What is LIMP Mode and how to fix it
    And how to reset the EPS
  13. #13
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    to reset the Toyota EPS - you need to connect it to a Toyota Tech Stream unit, there is no manual way of resetting it reliably. Your issue more sounds like the torque sensor in the rack is malfunctioning. It can go bad if its flooded with water.
    Any Toyota shop can reset it for you.
  14. #14
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    What now
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    do not spin the wheel quick to get it from lock to lock - the steering motor overheats and the system will shut down to prevent the motor from burning out.
  16. #16
    SER_GTR's Avatar
    Nov 2005
    30
    9,736
    16
    489 Post(s)
    19 Thread(s)
    EPS Need To Be Treated Nicely.....If You Overexcite It Too Much...It Will Enter Into Limp Mode Considering There Must Be Some Serious
    Issues With Car Alignment...Safety Precautions.....Its Not Hydraulic So Be Careful Using It.....The Rack And Motor Is NO Cheap....So As Its Replacement
  17. #17
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    didnt do it quick , just at normal spinning pace , and once at a slower pace too to check but the same result
  18. #18
    YasirAkram's Avatar
    Jan 2013
    its turn on whn driving for 1 to 2 sec and dissappear.... there is no error in ECU. Electrian says it mite b ABS sensor issue. is it possible???
  19. #19
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    Quote Originally Posted by YasirAkram View Post
    The issue is with his car
  20. #20
    RUSTY's Avatar
    Feb 2010
    28
    110
    salam brother i got the same prob and i was really worried but my problem was that one terminal of battery was loose so whenever the connection with the battery goes off it becomes hard so kindly chk it as well
