Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Vitz Power Steering Issue [Urgent Help Required]
    wasilrkhan's Avatar
    Dec 2007
    28
    545
    Unhappy Vitz Power Steering Issue [Urgent Help Required]
    Salam
    A friends Toyota Vitz model 2009, 2012 import is having power steering issue. The power steering turns off(steering becomes hard) sometimes when he comes to a stop at a traffic signal, then when he gives the engine some revs it again starts working.
    His car got washed first time from inside the bonet(without his knowledge maybe by brother) from a service station. There is also some water in the left side front light.
    What could be the issue and possible fix for this issue
    Waiting For replies
    EDIT:
    Just noticed something , the problem only occurs when the steering is put into full lock on either side.
    locked it 5-6 times to check and the same thing happened again and again.
    What now
    Regards
    Wasil
    Never give up, never back down, Always give a 110 percent,
  2. #21
    m.murtaza's Avatar
    Mar 2013
    12
    I am having a similar but in a way different issue. I had my steering bushes and others fixed on lathe ... I think this made the whole thing jamed ... and now after sometime of driving my steering gets hard, I can feel the EPS working but not its fullest... Can you @SER_GTR help me with that please, over here https://www.pakwheels.com/forums/whe...carolla-2010-a
  3. #22
    mehran4's Avatar
    Mar 2012
    51
    GOTO this link and you will find answer, its default techincal issue by company.
    http://www.autonews.com/article/2013...-steering-flaw
    Quote Originally Posted by wasilrkhan View Post
    Salam
    Waiting For replies
    EDIT:
    What now
    Regards
    Wasil
  4. #23
    m.murtaza's Avatar
    Mar 2013
    12
    My Issue has been solved it was due to metallic part replaced with Teflon rubber by the lathe machine guy
