Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By IsbCap
  • 1 Post By zahidsandhu223
Thread: Vitz 2005 - battery consumption in parked car
    Musa87's Avatar
    Jan 2012
    7
    Exclamation Vitz 2005 - battery consumption in parked car
    Dear All,
    I am using Vitz 2005. It is really a wonderful car. However, I have encountered the following problem:
    I use my car occasionally and normally it remains parked at my home. Just before this latest winter season began I changed my car battery as that battery was weakened. I placed OSAKA 60amp battery in it. I thought that I would give me some relief from tension to keep car running everyday but unfortunately it didn?t happen. Since I placed this battery I had to have a ride every alternate day (i.e. within 48 hours of previous ride) otherwise car refuses to start L
    Possible reasons that click in my mind are as follows:
    Poor quality battery that is discharged even by clock (timer) in parked car.
    Poor quality generator that do not charge battery properly.
    Plugs need service / tuning as almost a year have been passed since I got plugs change. However, I drove only 3,000 KM in last year therefore I think that plugs are not expired yet.
    Kindly identify the reason and it?s solution that you think appropriate in these circumstances.
    Tabish1's Avatar
    Feb 2007
    3,068
    24 Post(s)
    try this.. Park the car and remove battery -ve or +ve terminal.. and start it after 3 days..
    Pakistan <3
    Titanium's Avatar
    Sep 2007
    Dera ismail khan
    42
    513
    5 Post(s)
    Quote Originally Posted by Tabish1 View Post
    A better way of cornerign the problem, either in the battery or in the car.
    Of all the things i have lost, I miss my MIND the most...
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Ask some electrician to check for some possible short circuits in the vehicle. It may be "leaking" some current due to a short circuit.
    murtazee's Avatar
    May 2009
    38
    1,402
    3 Post(s)
    Dear same prob here with my city with same battery
    Just a week old, and it diffuses on third day. As i m off on sat sun so it do not starts on mon occasionally
    Sent from my iPhone using Tapatalk 2
    The time you enjoy wasting is not wasted time.
    Musa87's Avatar
    Jan 2012
    7
    @ murtazee,
    Have you found any solution for this issue ?
    I think i should visit electrician as suggested by IsbCap to check possible current leakage.
    inzi's Avatar
    Sep 2005
    39
    348
    5 Post(s)
    Quote Originally Posted by murtazee View Post
    Did you get any work done on the key / ignition? In original setting, the key wont come out. But if the person has not fitted it properly, the key would come out without turning it OFF completely...
    Make sure you are completely turning OFF the car and not just doing it "almost" completely.. This can leave some current leaking..
    zahidsandhu223's Avatar
    Oct 2010
    39
    Well Dear i Have Honda Civic Exi 2005. Same Problem With Me .I Checked It To Many Electrations They Checed All Wirings ETC no Fauly There At The End Result Com Out That i Should Put Off Negative Terminal Of Battery Believe Me I Do it And If i Start Me Ride After Two Weaks it Starts in Half Self but there is a Problem After Some Time Screw And Nut com Out Of Order Of Battery Wiring Terminal. It Cost 10 Rs.
