Results 1 to 4 of 4
Thread: ABS check light often ON in vitz 2007
    haseebjaveed254's Avatar
    Feb 2013
    Default ABS check light often ON in vitz 2007
    My vitz ABS check light often ON randomly, break fluid is ook, I hv done with tuning n computer twice frm toyota maintenence, the main prob is that during that check light ABS is nt working, plzzz help meee
    chdemon's Avatar
    Sep 2012
    1,439
    43 Post(s)
    Quote Originally Posted by haseebjaveed254 View Post
    12 - 13 lakh di gadi lay lai, 500 mechanic tay nai laya . Mechanic kay pass lay ja bhai.
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    prob wid abs sensors or sumthing !
    ZEE82's Avatar
    May 2009
    Peshawar
    34
    511
    23 Post(s)
    chek the wheel sensor connector grips.most probably they wud b loose
