Results 1 to 3 of 3
Thread: Vitz 1.0 engine cold start problem.
    Newbie Follow
    adeel_arshad's Avatar
    Feb 2013
    33
    Question Vitz 1.0 engine cold start problem.
    Hi Guys,
    I am facing one problem in my Vitz 1.0 model 2001.
    In the morning when I start it although it starts on the first attempt but I have to put the foot on accelarator till it gets warm enough around 1-3 minutes otherwise it drop rpms and dies also In that cold engine state if I put it in gear again it drop rpms and dies. After warming it around 1-3 minutes then no problem and everything works well. It is driven through out on Petrol no CNG.
    I already got throttle body and Air flow sensor cleaned up but It didnt fix the problem.
    Any ideas what else do I need to get check up / fix ?
    hash4u's Avatar
    May 2005
    38
    24,377
    18
    406 Post(s)
    13 Thread(s)
    13
    a friend had same problem
    but it was valve damage due to CNG driving. thanks to toyota dohc engine plus our people using cng on them
    car needed a head fix
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Spark plugs need to be changed.
    Never loose hope in life,every step gives u something.
