Results 1 to 9 of 9
Thread: Vitz Remote-Push Start Issue
    Docjunaid's Avatar
    Mar 2012
    Sadiqabad
    2,046
    48 Post(s)
    2 Thread(s)
    Default Vitz Remote-Push Start Issue
    Aoa
    I need some help regarding an issue i faced today
    The car didn't start when i used the push start today, Key Check light kept coming on & i tried to place the key everywhere close to sensor but it didn't work!
    Battery was fine, hids worked fine
    So i did unplug the battery & reattached it, still Key Check-light came up & car didn't start.
    Then i decided to check the battery of Remote, it was blinking upon pushing
    Somehow i kept on trying & on like 50th attempt the car started & i came back home
    I tried to start the car few time when i came back home & it started normally
    QUESTION IS HOW SHOULD I PROCEED TO SOLVE THIS PROBLEM
    Any Help Will B Highly Appreciated
    Thanks
    Sent from my iPad using Tapatalk HD
    Glory Glory Manchester United
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    brother, i dont have a vitz,
    but own a passo smart key car,
    the problem must be with your remote's battery ( im 90% sure)
    even the LED on remote is blinking, check after changing its battery(remote).
    if this doesnt work, then you have to check other things,
    can you tell me if its small button or door handle is working or not ?
    jiyo aur jeenay do
    CutePoison's Avatar
    Nov 2010
    855
    The battery in your remote must be dead. Replace it
    And next time this happens, touch your remote with the Start/Stop button for 10seconds . The light on your start/stop button will turn on and then start the car normally. This worked for my car
    Salarzae's Avatar
    Sep 2005
    Select City
    12,477
    31 Post(s)
    3 Thread(s)
    @doc
    This might happen due to a few reason's but I'll mention the ones I've experienced.
    1- The cable plug for the receiver antenna in the car might loosen up and will stop receiving signals intermittently from the remote. I'm not sure where you can find one in Vitz. In my car, it is right under the steering column.
    2- Not sure if Vitz has same function like the one mostly used in KIA & Hyundai but a faulty brake switch can also trigger the same issue. Replacement might be the only option if that's the case.
    This Space Intentionally Left Blank.
    Docjunaid's Avatar
    Mar 2012
    Sadiqabad
    2,046
    48 Post(s)
    2 Thread(s)
    Thx guys
    Just got new battery cell
    It is really difficult to find these CR 16-32 cells
    Im going to try this now lets see what happens
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    you have to hold the key fob flush to the button for quite some time, upto 30 seconds in some cases, the button will finally light up and allow the engine to fire.
    Docjunaid's Avatar
    Mar 2012
    Sadiqabad
    2,046
    48 Post(s)
    2 Thread(s)
    Thx Xulfiqar Bhai
    Changing the cell did the trick
    Now Push Start & Remote Key are working fine
    askaricars1's Avatar
    Feb 2013
    15
    check the battery of remote control,most probably this is the problem
    Docjunaid's Avatar
    Mar 2012
    Sadiqabad
    2,046
    48 Post(s)
    2 Thread(s)
    Yup Battery Was The Culprit
    Problem Solved
    Thank You EverOne
    MODS can close this thread
    Cheers
