Results 1 to 10 of 10
Thread: best plugs for vitz
    kazim104's Avatar
    Sep 2012
    Faisalabad
    140
    3 Post(s)
    Default best plugs for vitz
    best plugs for vitz , i gonna change it
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    Model
    If its 2006 model the 3 cyl engine then denso sr long choori iridium
    Sent from my A10 using Tapatalk 2
    Hanjiii Kaa Storeey Eehh !
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    It will be written on a sticker under the hood and in the owners manual.
    "Imagination is more important than knowledge"
    kazim104's Avatar
    Sep 2012
    Faisalabad
    140
    3 Post(s)
    Quote Originally Posted by ekdrifter View Post
    Model
    its 2007 model bro.
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    best plugs for vitz -1151528
    sk 20
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    Here is vitz genuine plug. Read it on a friend's vitz underhood sticker.
    Denso K20HR-U11
    kazim104's Avatar
    Sep 2012
    Faisalabad
    140
    3 Post(s)
    Quote Originally Posted by Haji__John View Post
    Denso K20HR-U11
    its for 1000cc or 1300cc ??? if vitz genuine plug is denso K20 Hr-u11 then why every one is asking for denso iridium sk20hr11 ?? confused !!
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    The use of Iridium is only to increase the service life, that is the only thing even claimed by the manufacture denso in this case. And since the service intervals of our cars are not the same as abroad due to really harsh driving conditions and the way we maintain our vehicles with cheap spares, there is absolutely no point of using an expensive plug for very long service life. Just put in a simple copper tip and throw it away after 25K if you feel like, even after three such iterations you might not reach the cost that you would incur for iridium which are utterly useless in this case. All the thing claimed by here by the change of plugs are baseless, maybe the genius also got a fresh oil change when he changed the plugs and then calimed meri to gari badal gayi yar :-)
    The following are stock plugs for a vitz 1KR-FE engine :
    DENSO K20HR-U11
    NGK LFR6C-11
    BOSCH FR7KCU
    I have a personal inclination towards NGK although I am aware that denso came as the OEM ones in vitz
    Apart from pakwheels, my blogs can be also be viewed at http://tajziat.blogspot.com/
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    O yar if its 1000cc 1kr-fe engine then its the denso plug mentioned above.
    If its a 1300cc 2nz-fe engine then denso K16R-U11.
    If its a 1300cc 2sz-fe engine then denso K16R-U.
    If you don't know which engine u have then its written on the chassis plate. If you still don't understand then post a pic of your engine.
    Quote Originally Posted by kazim104 View Post
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,106
    5
    185 Post(s)
    12 Thread(s)
    denso sk20hr11,denso ikh20 vkh20 n ikh01 are oem plugs for ur 1krfe,no other plugs by denso will fit properly
    locally only sk20hr11 are available
    best plugs for vitz -1151976
    www.facebook.com/performancepartslahore
