Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Like Tree4Likes
Thread: Vitz 2005 Vibrating & Knocking
    Newbie Follow
    Asim200276's Avatar
    Apr 2013
    Default Vitz 2005 Vibrating & Knocking
    I have Vitz 2005, Now adays I am facing problem that when I stop and was in D that car was vibrating. Also when I was on my AC then some time engine was off. Can anybuddy advice me about these problems or give me any good mechanic tel no. to fix thi problem.
    Asim
    aftab87's Avatar
    Jul 2010
    Mombasa
    29
    23
    Remove the Throttle Body and clean off the carbon inside especially on the butterfly with any carbon cleaner or with petrol. Let me know if your problem is solved
    Hesab_Magsi's Avatar
    Aug 2010
    Quetta
    26
    1,739
    31 Post(s)
    This used to happen with my vitz aswell,had to sell it off
    Docjunaid's Avatar
    Mar 2012
    Sadiqabad
    2,046
    48 Post(s)
    2 Thread(s)
    Kindly look up VITZ OWNERS/FAN CLUB on pakwheels
    This issue is discussed in detail there
    In short as mentioned start with throttle body cleaning, get plugs checked, use almost all the fuel u hv in the ride & get it filled @ some good pump preferably hi octane 30% & supreme 70% or simply quality fuel
    These steps hv solved most ppl's problems
    Glory Glory Manchester United
    aftab87's Avatar
    Jul 2010
    Mombasa
    29
    23
    Well said@Docjunaid
    uzeemujeeb's Avatar
    Dec 2008
    381
    5
    4 Post(s)
    also check engine oil & oil filter
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    i have vitz 07 and 1000cc. And having the same vibration issue when stand still in gear D. i have done everything. throttle body clean and then changed, battery changed, alternator changed, transmission oil, oil filter, air filter. clean the iridium plugs, clean the fuel filter clean, foundation rubber changed. but problem is still there. use hi octane 70 % and normal petrol 30%. what can be the cause now. already spend lot of money. But vibration is still there. anyone can help me pleaseeeeeeeeeeeeeeeeeeeee
    although pick is fine, no other mechanical issue but mileage in full tank is 300 km which is very bad
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    knocking issue is with all vitz above 2005 due to bad quality petrol use hi octane after throttle body service
    @ amjad check ur car oil pump k whether it is circulating oil perfectly as this happened in my relatives passo but it was making weird sound as well and have u checked the by diagnostic equipment ? we can just rectify the problem by it
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    Thanks Asad for suggestion. checked/verified through computer scanner, everything is perfectly okey. i will definitely show the oil pump too. But don't think that it will be the problem.
    haris457's Avatar
    Jan 2006
    Rawalpindi
    35
    616
    6 Post(s)
    Quote Originally Posted by Asim200276 View Post
    Asim
    bro same problem i faced after getting air filter changed.the problem which was there that that housing for air filter wasnt properly seated and it was taking air,got it fixed myself and now everything is fine
  11. 04-06-2013, 02:57 PM
    jz
    Senior PakWheeler
    Reason
    off topic
  12. 04-06-2013, 03:06 PM
    Senior PakWheeler
    Reason
    off topic
  13. #11
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    i think i know what is causing the problem with my car, but don't know how to solve it. My car voltage is 12.7 when ignition on. it should be around 13.5v to 14v. Already showed alternator to different electricians, they just told me that it is working fine. But i was not satisfied so decided to change my alternator. after changing the alternator with the kabli one, same output i am getting. Now i am thinking maybe the kabli alternator/generator is also faulty. yeah in the mean while i managed to installed raizin voltage stabilizer but no difference. I have installed new battery AGS ns 60 too. i am totally confused. please help. Thanks in advance.
  14. #12
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    so i have changed the alternator again, and the voltage problem resolved. now my car on idle is giving 13.9 and on push the paddle it reaches 14.2. But vibration problem is still there. Now i am planning to change the iridium plugs and fuel injector clean. Any suggestion.
  15. #13
    ajjubravo's Avatar
    Aug 2005
    1,040
    5 Post(s)
    You have to clean the wall body of your car's transmission located inside the transmission chamber!
    It have 4 springs in it which gets carbon deposited on them and hence car starts to vibrate in D or R!
    Get it cleaned from a good mechainic your problem will be solved!
    Throttle Body Do Not make this type of issues in a vitz but bad throttle body gives bad economy and poor throttle response!
    Sent from my HTC One X using PW Forums mobile app
    Mod Edit: Commercial selling is not allowed!
  16. #14
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    I have changed the CVT transmission oil last month. do i still need to clean the chamber too? as the mechanic open the chamber, drain the oil and clean the chamber cap and fix it with silicon. I am hoping we are on the same page.
  17. #15
    ajjubravo's Avatar
    Aug 2005
    1,040
    5 Post(s)
    You need to clean the wall body mate located above the transmission filter!
  18. #16
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    Cleaning the wall body changed nothing. Same vibration I am having. Another thing when I bought the car the housing of heater pipes were removed from the throtle body. May it cause the problem? Exuast system checked and airintake box check no leakage found. May be electric wiring of the car damage. I have changed the iridium plugs too recently and the oem. Original oil filter and air filter placed this month. Shifted to shell blue box oil hx7 20w 30. So much fedup with this vibration. Anyone with suggestions. Really need your expertise in that.
  19. #17
    Ali_Mujtba's Avatar
    Apr 2012
    Faisalabad
    198
    3 Post(s)
    I have the solution, 90% chances it will work,
    Adjust the gap between accelerating paddle and the plastic type thingy which works as stopper above the paddle, with some foam tape.you can easily do it yourself or give this hint to some workshop man, he can do it for you.
    Adjust the gap such that your required engine RPMs are achieved.
    Total time = 10 min. Total cost = Rs.10
  20. #18
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    Thanks Ali bhai for suggestion. I will try to explain this to mechanic. I bought vitz 4 months back and first time when I went for general check up and throttle tuning they showed me that first owner placed a piece of paper in acceleration paddle to have increased rpm but that is risky because brakes will not work properly especially when engine is cold and running in high rpm. Is that true? I am having vibration problem when engine is hot. In cold engine no vibration at all. One thing more a little vibration start even in parking and nutral gear when I close or open the window or press horn. Can it be possible leakage in wiring between ecu or battery or alternator or may be any fuse fualty.
    If no other solution and no risk envolve then I will place foam tape as I am traveling with my little baby and family.
    Ali bhai have you done this before? Thanks again.
  21. #19
    Ali_Mujtba's Avatar
    Apr 2012
    Faisalabad
    198
    3 Post(s)
    Bro, i have also same model 2005~06 vitz. i had suffered alot for this problem too, in my vitz the problem was so severe that its engine used to shut off, problem nature was almost similar to yours. than 1 day mechanic showed me this thing, the foam tape placed in paddle by previous owner had torn off, so the problem was rising.
    For your other reservation,it is total risk free as far as i have tested it, have run it for about a year now. i myself have become expert in this now,hahaha..whenever after 3,4 months old tape is torn, i myself fix it and adjust the RPMS.
    Moreover when i didnt knew this problem, i got checked each and every fuse, but problem had not vanished. ALHAMDU LILLAH now i m in peace.
    When engine is cold and on high RPMs, just be conscious for 1st 1 min, thats all.
  22. #20
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,960
    12 Post(s)
    Use Hioctane fuel thts the only cure or get a Unichip or some fuel management system.They will adjust AFR mixture asper local normal fuel quality.All these JDMs are designed for hioctane
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
