Results 1 to 9 of 9
Thread: which tyres in vitz
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    Default which tyres in vitz
    which tyres should i put in vitz. & which size also. my running is on both types pf road. kachee & pakee. pakee par ziadaa hai running.
    Why drink and drive when you can smoke and fly?
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
    hash4u's Avatar
    May 2005
    38
    24,380
    18
    406 Post(s)
    13 Thread(s)
    13
    u should check the post with title
    vitz fan club
    agha300's Avatar
    May 2005
    Somewhere
    42
    3,593
    2 Post(s)
    @sd
    dont mind if i say first pls get urs age corrected or try to be 18
    lols
    bro jus kiddin
    u cxan put 195/50/15.
    it suits best
    @Storm recently put them in his vitz. Brand was PIRRELLI
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    which size rim do you have on the car. according to that i'll give you all the available options.
    also check this link:
    https://www.pakwheels.com/forumreply...mID!17~pw.html
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    i,am having R13. but when i will change tyres i will fix R14.
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
    Deloy's Avatar
    Apr 2006
    41
    203
    Keep r13, r14 a\is a bit heavy for 1000 CC version with softer suspension, go for 185/70/r13, wil give you better ground clearance and good grip, with affecting suspension that much
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    Vitz 1000cc OEM tyre size 155/80R13 (578mm Diameter)
    Suggested tyre size by Deloy 185/70R13 (589mm Diameter)
    Difference is +1.9% or 11mm which is within the OEM 2% margin of error, however i'd suggest the following:
    165/75R13 (578mm),
    175/70R13 (575mm)
    195/65R13 (584mm)
    For 14's i'd suggest the following setup:
    185/60R14 (578mm),
    175/65R14 (583mm),
    165/70R14 (587mm)
    If you want to go 15 i suggest the following:
    165/60R15 (579mm),
    185/55R15 (585mm),
    195/50R15 (576mm)
    No matter what anyone tells you, avoid 205's, they will rub on the inside of our arches ever if you use an ET 45 (offset) rim which is the limit of the vitz (ET should be between 38 & 45 to maintain propper suspension geometry)
    it's best to try and stay as close to 578mm as possible. I went for 195/50R15 because it is a good balance between wider foot print (good braking & grip) & decent sidewall height (smooth ride).
    Good luck on your decision & purchase.
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    hey storm bro. which company tyres should i put in R15. yokohama aspec, hankook, bridgestone techno360, dunlop sp sport.?
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    Funnily enough i got the best deal from Pirelli. So i got a set of Pirelli dragons 195/50R15 (576mm). it's more up to personal choice but at the end of the day i got a set of 48th week of 2005 tyres (production) for my vitz which were newer than anything else on the market, and in the same price range (18000)
    I had to wait 1 week for them to be cargo'd to ISB from KHI (at no extra cost) but the tyres were worth the wait. and i have full guarantee on them.
