Results 1 to 3 of 3
Thread: best place for vitz 2006 throttle body service and tuning in Lahore
    toyota_vitz's Avatar
    Apr 2013
    40
    3 Post(s)
    Default best place for vitz 2006 throttle body service and tuning in Lahore
    I want to service throttle body and tune up engine of my vitz.
    Please suggest best place.
    Also want to change timing belt.
    Ehsan4808's Avatar
    Sep 2007
    34
    1,816
    7
    53 Post(s)
    Throttle Body Service , go to any wshop.. be it road side or a 3s dealership.. No science in opening a TB and cleaning it with Petrol or Carb Cleaner spray!!
    Nothing to tune ! just replace air filter and spark plugs if they are weak. Your done..
    2ndly, there is no timing belt in Vitz.. Its has a timing chain, which would make noise when it needs to be replaced.
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,960
    12 Post(s)
    Buy a NASA,7CF or any good brand Carb cleaner.Open filter box and crank the engine.Ask someone to rev the engine and simply spray the carb cleaner. Thts it.If car shut downs no need to be worried simply crank it wth accelrator depressed.
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
