Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 70
Like Tree6Likes
Thread: Recommend Oil for Toyota Vitz
    YARIS.10's Avatar
    Aug 2010
    184
    Default Recommend Oil for Toyota Vitz
    Kindly recommend me engine oil for my car.
    what is company recomendation.
    Detail is following
    Toyota Vitz
    1.0
    2007
    86000km on ODO
    Monthly running 2600 Km
    Area Lahore( extremely hot now days)
    Thanks
    VITZ:A Master Piece by A Greek Designer
  2. #41
    hamza_077's Avatar
    Jul 2011
    21
    144
    I also have a corolla 2009 gli 34,000 kms driven and used Mobil 20w50.Is it fine?
  3. #42
    imrananr's Avatar
    Jun 2014
    847
    5
    19 Post(s)
    20W50 is way too thick with 34,000 on the ODO.
    Use 5W40, full synthetic engine oil.
    Don't leave a highway for a byway....
  4. #43
    Waqash's Avatar
    Feb 2006
    37
    35
    Below is just to share my good experience with Caltex Havoline Fully Synthetic SAE 5W-40.
    I had imported Vitz 2007 1.0L in August 2012 with genuine 7000Km on ODO. Drove it fine on the Japanese petrol and engine oil before taking it to Toyota Defence Motors in DHA Karachi. Those fools poured in the locally blended Toyota 20W50 and the drive changed drastically. After going through its user manual (in Japanese) and doing some research I immediately switched to Caltex Havoline Fully Synthetic SAE 5W-40 (Golden packing). It has been more than 2 years, ODO now shows more than 31,000 and the engine is going super fine in terms of sound, oil level, fuel consumption and no deposits inside. I change the oil at around 5-6,000 km interval.
    From the beginning there is rare (like on speed breakers etc) and very slight knocking sound on regular petrol that too only with AC turned on which completely goes away on mixing a little Hi Octane.
  5. #44
    hamza_077's Avatar
    Jul 2011
    21
    144
    I just changed the oil today in my 09 corolla gli Mobil 20W50.
    What you think should i replace it immediately or should keep it running.Would it cause any harm to engine?i am worried.
    Before this i used Genuine Toyota motor oil.
  6. #45
    imrananr's Avatar
    Jun 2014
    847
    5
    19 Post(s)
    It's better you change it at the earliest if possible.
  7. #46
    arzaam.bhatti's Avatar
    Jun 2014
    20
    2,469
    6
    87 Post(s)
    Quote Originally Posted by hamza_077 View Post
    Was it in this packing?
    Recommend Oil for Toyota Vitz -1567885
    none of toyota oils are satisfactory either, ill personally recommend 5W-40 fully synthethic in any brand, if you fancy mobil1 then use 0W-40 not this, or if you have must use toyota oil use their newly launched Taglon, its fully synthetic but will cause some drop in fuel economy and performance at the expense of engine cleanliness.
    If everything is coming your way, you're in the wrong lane!
  8. #47
    hamza_077's Avatar
    Jul 2011
    21
    144
    @arzaam.bhatti yes it is this one.
    I'll replace it by 5W40 fully synthetic motor oil
  9. #48
    Jun 2014
    20
    2,469
    6
    87 Post(s)
    i had a feeling it would be this one,replace it on emergency measure, to whoever told you to get this very oil in your car tell them to refund or keep it for themselves. this is extremely harmful for your car not just because of viscosity but because of its api rating its API SF! not for use for any engine after 1988, i woundnt use this in mehran even. get rid of it asap its obsolete and cause serious damage. its intent for classic cars and i have seen people use it in motorcycles but no car after 1988.
    people try to suggest anything just to get rid of it you should take this oil back to where you bought it and get a refund. show them its api rating.
    toyota petron is API SH which is also obsolete and their petrol plus is API SL which is better but you car requires API SM at the very least. SN will work as well
    see this chart
    http://www.api.org/~/media/files/cer...glish_2013.pdf
  10. #49
    hamza_077's Avatar
    Jul 2011
    21
    144
    Thanks a lot for your great guidance and feedback sir!I've learnt a lot now and will never repeat this mistake again.
  11. #50
    faizy46's Avatar
    Mar 2009
    Peshawar
    28
    99
    Guyz kindly tell me how many liters to pour into my vitz 2011?
  12. #51
    imrananr's Avatar
    Jun 2014
    847
    5
    19 Post(s)
    Quote Originally Posted by faizy46 View Post
    The engine oil replacement is of 3.1 litres (with filter replacement) for Vitz 1.0 L / 1kr-fe engine.
  13. #52
    tintin1's Avatar
    Jan 2014
    1,842
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    For 1KR-FE
    3.1L is without oil filter and with oil filter the engine oil capacity is 3.4L.
    Most of the people pour 3.5L thinking that slightly more oil is OK.
    Be Addicted To Help Others.
  14. #53
    imrananr's Avatar
    Jun 2014
    847
    5
    19 Post(s)
    Quote Originally Posted by tintin1 View Post
    For 1KR-FE
    I think for 1kr-fe engine, it's 3.1 litres with filter replacement; please re-confirm.
  15. #54
    faizy46's Avatar
    Mar 2009
    Peshawar
    28
    99
    For 1KR-FE
    Bro r u sure, shall i go with 3.1 liter or 3.5 liter with filter?
  16. #55
    imrananr's Avatar
    Jun 2014
    847
    5
    19 Post(s)
    Confirmed, it's 3.1 litres as below:
  17. #56
    faizy46's Avatar
    Mar 2009
    Peshawar
    28
    99
    Quote Originally Posted by imrananr View Post
    Ok i will go with 3.1, thanks bro.
  18. #57
    tintin1's Avatar
    Jan 2014
    1,842
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    if you will pour 3.1L only, then dip stick will show slightly less oil level.
    Go for 3.4 or 3.5L oil for 1KR-FE.
    I've asked to my friend and he confirmed it will take 3.5L.
  19. #58
    imrananr's Avatar
    Jun 2014
    847
    5
    19 Post(s)
    Some times it's difficult to crack a taugh NUT.
  20. #59
    Cr33D's Avatar
    Nov 2012
    Rawalpindi
    21
    585
    15 Post(s)
    im gonna get my oil changed today, will pour in 3.4 litters.
    When I looked up "Ninjas" in Thesaurus.com, it said "Ninja's can't be found" Well played Ninjas, well played.
  21. #60
    tintin1's Avatar
    Jan 2014
    1,842
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by Cr33D View Post
    Good luck.
