Page 4 of 4 FirstFirst ... 234
Results 61 to 70 of 70
Like Tree6Likes
Thread: Recommend Oil for Toyota Vitz
    YARIS.10's Avatar
    Aug 2010
    184
    Default Recommend Oil for Toyota Vitz
    Kindly recommend me engine oil for my car.
    what is company recomendation.
    Detail is following
    Toyota Vitz
    1.0
    2007
    86000km on ODO
    Monthly running 2600 Km
    Area Lahore( extremely hot now days)
    Thanks
    VITZ:A Master Piece by A Greek Designer
  2. #61
    Cr33D's Avatar
    Nov 2012
    Rawalpindi
    21
    585
    15 Post(s)
    Quote Originally Posted by tintin1 View Post
    Good luck.
    I didn't buy the engine today as i got confused, i was gonna buy liqui moly but i realized the car would be driven with in city for usually short distances, there's no way it can cross more than 3K km in 6 months. Which oil do you recommend for 2012 vitz ?
    When I looked up "Ninjas" in Thesaurus.com, it said "Ninja's can't be found" Well played Ninjas, well played.
  3. #62
    tintin1's Avatar
    Jan 2014
    1,832
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by Cr33D View Post
    It will be very odd to use LM oil because its imported and we can run the car around the world in once change engine oil.
    Just feed your Car ZIC A+ 5w-20 which is more suitable for it. And you can change it when your car do 5K.
    Be Addicted To Help Others.
  4. #63
    Cr33D's Avatar
    Nov 2012
    Rawalpindi
    21
    585
    15 Post(s)
    For vitz 5w-30 is recommended or shot i go with 5w20 ?
  5. #64
    tintin1's Avatar
    Jan 2014
    1,832
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    First choice ZIC A+ 5w-20
    2nd choice ZIC OW 0w-30 (non-hybrid)
    3rd choice 5w-30
    First two given choices are BEST for better fuel economy throughout the year.
  6. #65
    Cr33D's Avatar
    Nov 2012
    Rawalpindi
    21
    585
    15 Post(s)
    3rd choice 5w-30
    I got A+ 5w-20, got the 4 liter one as i thought 3.4 liter will pour in but according to the manual, 3.1 L of oil has to be poured in 1KR engine.
    The oil level on dip stick is little bit above the threshold level.
  7. #66
    imrananr's Avatar
    Jun 2014
    837
    5
    19 Post(s)
    Read my post#55 on this thread, I clearly told you that the manual says 3.1 litre for 1kr-fe engine with attached proof from manual but you did not understand and followed some one else's instructions leading to this over filling of oil.
    The correct oil level is between the min. and max. mark of the dipstick while the engine is cold and vehicle parked on a flat surface.
    Over filling can lead to leaking engine seals ( not necessary).
    Why did you go for 5W20. Should have gone for 5W30.
    Don't leave a highway for a byway....
  8. #67
    Cr33D's Avatar
    Nov 2012
    Rawalpindi
    21
    585
    15 Post(s)
    I didn't pour 3.4 L, the station guy poured little over 3.1 which is alright i guess, No harm. and No reason for getting 5w20 over 5w30.
  9. #68
    tanoli16's Avatar
    Jul 2014
    63
    Default correct oil is this
    Pls tell me How is 10W30 Engine OIl for Vitz 1KR-FE plz??
    see temp.chart for oil, if U have pls share it .
    regards
  10. #69
    tintin1's Avatar
    Jan 2014
    1,832
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Manual says 3.1L without filter.
    With Filter its 3.4L is confirmed capacity.
    If you want to prove it, then add 0.3L more and I bet dip stick will still show the same level.
    Actual recommended oil for 1KR-FE for best fuel economy is 0w-20.
    And feeding it 5w-20 is the best wise decision either its summer or winter. Just keep using it.
  11. #70
    tintin1's Avatar
    Jan 2014
    1,832
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by tanoli16 View Post
    regards
    read this
    https://www.pakwheels.com/forums/oil...-1kr-fe-1nr-fe
