Results 1 to 3 of 3
Thread: VITZ 1999 Automatic Transmission problem, Maybe?
    kasaas's Avatar
    Apr 2006
    37
    973
    12 Post(s)
    Default VITZ 1999 Automatic Transmission problem, Maybe?
    aoa, our house hold vitz99 automatic hessitates to change to second gear. If accelerated if gives a increased race sound and jerk. If i let go of pedal a little and then accelerate it changes to second gear and then gears change smoothly. Only happens on 1 to 2nd gear change. Auto transmission fluid was changed an year ago on 58 k odo. was run on cng for 4 years but now for an year running on petrol only. Hi octane helps a little.
    Is it atransmission probem or the catalytic converter problem. check engine light is on for last 2 years as mechanics says it was due to cng.
    I tried changing the sparks with less old ones but no use. car has been with us since 2006 but no sparks changed. it was at 30 k odo then.
    Plz help. Does 99 vitz have atf filter tat i can get changed. Ive parked the car at home so no more damage occurs before its fixed.
    BEST THINGS IN LIFE R NEVER FREE
    kasaas's Avatar
    Apr 2006
    37
    973
    12 Post(s)
    come on!!! no one has this problem
    kasaas's Avatar
    Apr 2006
    37
    973
    12 Post(s)
    does not matter now! ive sold the car. Mod can close the threaf
