Results 1 to 6 of 6
Thread: Xulfiqar need ur help for vitz valve clearence
    Rhagvan's Avatar
    May 2013
    120
    Default Xulfiqar need ur help for vitz valve clearence
    i have a vitz 2003 model running on CNG . jab mai car start karta hon lamba self le kar start hoti hai aur agar accelerator na do band ho jati hai . pakwheels per search kiya to pata laga valve clearence karani hogi according to u its a expensive procedure hai .is condition mai car chalana sahi hai ya nahi car chalne mai bilkul fit hai pick wagera sab set hai bas AC per break halkay ho jatay hain . is procedure per kitni cost aai gi kyn k mechainic to pocket khali kar detay hain . agar complete head hi change kar do to masla solve ho jae ga ya nahi . is condition mai chalane mai koi harj to nahi hai
    Rhagvan's Avatar
    May 2013
    120
    time to bump
    uzeemujeeb's Avatar
    Dec 2008
    381
    5
    4 Post(s)
    get it scanned on computer aur uss ki throttle body ko check karwa layn, yeah valve clearance ka masla nahi hai VVTi engine valves seldom go out of clearance under periodic maintenance.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    adjusting it on any new toyota head with solid lifters requires replacement of lifters - toyota make 11 different size ones for this purpose. The short cut approach in Pakistan is to grind the valve stems which is terrible practice because valves are hardened items.
    Running with tight clearances will cause lazy performance and also problematic behaviour in the cold. If you neglect it far enough you might burn the valve seats.
    Rhagvan's Avatar
    May 2013
    120
    yaar to is ka solution kya hai
    new head from scrap with valves OR just change only valves
    ya phir kuch aur karon aap bata do
    Rhagvan's Avatar
    May 2013
    120
    mechanic ko dikhaya tha bol raha hai valve change honge iske
