Results 1 to 10 of 10
Thread: VITZ 06 engine check light ON
    saqibnawaz1's Avatar
    Jun 2013
    29
    10
    Default VITZ 06 engine check light ON
    aoa brother
    kindly i hav few problems with my vitz 06 eco
    1. engine check light on
    2. engine giving white smoke when i press accelerator hard while in parking mode, engine oil level is alwayz stable.
    3. inherent knocking noise
    sir i am worried these issues and kindly suggest best suitd engine oil and other things , plz.
    Jun 2013
    29
    10
    engine check gets ON once i drive 8-10 kms and sometyms doesnot..plz help me out broz
    baqai's Avatar
    Apr 2004
    39
    2,560
    47 Post(s)
    get the car checked as soon as possible from toyota with diagnostic so you can figure out the problem, it might be bad quality fuel but i think problem is more than just that
    Lost in /dev/null
    Jun 2013
    29
    10
    ok today i will go positively and get it checkd.. what else it can be ?
    livilr_invisible's Avatar
    Jul 2011
    40
    which oil have you used, may be it is due to dirty fuel injector or spark plugs white smoke means its burning raw fuel the best thing to do is get it diagnosed and check the codes, hope this helps
    1- False friends r worst than open enemies , 2- Only Youth can change the system
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    You can reset the computer by unpluging the + terminal of battery & put it back after 2 min... if that was some sensor problem it will resolve & still if it is on then car need a serious attention.. for smoke do chek with good mechanic... I hope u dont wash the engine bay...
    Jun 2013
    29
    10
    thanx broz
    never washed from inside..
    i bought recently and havnt change oil yet .. seller told that he put Shell 15w50 of 3 lits
    Jun 2013
    29
    10
    one thing is once i opened oil filler neck ... ther was dirt/black sand type sticked on inside of oil filler neck
    ajjubravo's Avatar
    Aug 2005
    1,040
    5 Post(s)
    Looks like a dirty o2 sensor to me!
    Get the o2 sensor cleaned with carb cleaner and 320 grid sand paper
    Use castrol gtx in your car smoke will stop periodically!
    Get throttle body cleaned and get spark plugs replaced!
    Inshallah all of your problems will be solved!
    Sent from my HTC One X using PW Forums mobile app
    Mod Edit: Commercial selling is not allowed!
    Jun 2013
    29
    10
    i should go to TOYOTA mechanic only ??
    i am in karachi ..
    here friends suggests me to go to Toyota Eastern ..
Tags for this Thread
