Results 1 to 5 of 5
Thread: AC help required - Vitz 2008
    qasimmansoor's Avatar
    Sep 2008
    30
    51
    Lightbulb AC help required - Vitz 2008
    Dear All,
    I am experiencing AC cooling issues in my vitz. Problem is that when it works it works perfect but it stops after some time n then starts again after some time. Also i have noticed that the AC works fine when car speed is more than like 60 KM and stops working at all when speed its slow like when it signals. I have checked AC gas and its fine. It would be great if anyone could advise a way forward. Also please suggest the name of AC mechanic in Islamabad who can fix this problem.
    Thanks in advance.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    when did u get ur system serviced ? and replaced drier bottle
    Seems like that the gas is not freely circulating in the system need high pressure from compressor to circulate
    ur system is choked need service and some parts replacement as well like drier bottle and 1 part which is installed in cooling coil dont remember the name
    nido807's Avatar
    Feb 2011
    1,174
    4 Post(s)
    get it checked from abu bakar universal car ac
    mfarhansabir's Avatar
    Sep 2012
    838
    11 Post(s)
    3 Thread(s)
    Quote Originally Posted by qasimmansoor View Post
    Dear All,
    Thanks in advance.
    Is the condensor fan working? Or is the condensor choked?
    Check that before opening up the AC.
    Sent from my GT-I9103 using Tapatalk 2
    SER_GTR's Avatar
    Nov 2005
    30
    9,734
    16
    488 Post(s)
    19 Thread(s)
    Did You Check The Climate Control Thingy???
    The Thermostat Is Responsible For Tripping The System As Per Temp.......! Any Betterment In Night???
    You Can Also Check Your Cabin Filter 1st and Clean It Up Also....Clean You Condensor With Mild Pressure Air And Then Spray Water And See If It Gets Any Better
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
