Results 1 to 9 of 9
Thread: vitz 2001 rear shock absorber broken help needed
    disisfifty's Avatar
    Sep 2007
    32
    234
    Default vitz 2001 rear shock absorber broken help needed
    okay guys, since two days I was noticing weird noise like tire bouncing whenever going over an uneven patch on the road. Annoyed from the fact, I decided to take matter into my hand and started looking for the issue and snapped two photos to share on the forum, one of right side shock absorber and other of left side shock absorber. please look at the pics attached below. vitz 2001 rear shock absorber broken help needed -1225165vitz 2001 rear shock absorber broken help needed -1225166 okay so we have established that one of the shock absorber is broken, I have following questions in mind, 1. please specify that weather is can be repaired or it should only be changed, 2. can I find it brand new or I need to go for a used one, 3. do I need to change both the sides or changing one is equally good, 4. what is the best workshop for the job in Lahore, 5. what kind of expense is I am looking at.
    nfssaad's Avatar
    Oct 2006
    29
    3,179
    50 Post(s)
    brand new mil jai ga... go for kyb or monroe or tockiko only gas filled shocks.. and you will have to buy pair
    the problem is not our govt... its the people..
    disisfifty's Avatar
    Sep 2007
    32
    234
    thanks for reply nfssaad, will the height of my car be altered after installation of new gas shock or they all are of same size? any guess abt the price?
    disisfifty's Avatar
    Sep 2007
    32
    234
    can this be a possibility that only the cover is broken and the inner piece is still intact? even if that is the case the tire is still making tak tak sound on bumps. please guide
    manobilla16's Avatar
    Oct 2008
    33
    123
    3 Post(s)
    i had the same issue .... its not the shock broken... its the jumper rubber of the shock which is broken.... i bought the kabli for 500 and Rs150 was the labour to replace it.... if u live nearby to DHA i can guide u from where i bought it....
    disisfifty's Avatar
    Sep 2007
    32
    234
    @manobilla16
    brother I live in DHA X Block near HKB. please guide me about the location of the shop
    Oct 2008
    33
    123
    3 Post(s)
    Quote Originally Posted by disisfifty View Post
    @manobilla16
    there is a kharadia on walton road... have you seen the utilty store on walton road, there is a market beside it you can get them from there. for more info call me on 03005530000 (Bilal)
    disisfifty's Avatar
    Sep 2007
    32
    234
    yup have seen the utility store, anyways I will give you a call in the evening. thanks so much for the help
    car_bus2008's Avatar
    Jan 2008
    1,770
    23 Post(s)
    2 Thread(s)
    and i bought whole shock rear right side for Rs 1500 and fixed it my self at home.
    Money differs from an automobile or mistress in being equally important to those who have it and those who do not.
