Results 1 to 2 of 2
Thread: Vitz Compressor Bearing
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Default Vitz Compressor Bearing
    AoA guys
    My Vitz 1.3L clutchless Compressor "DENSO 5SER09C" pulley bearing is making lil noise, i want to replace the bearing without removing the compressor from Engine, there is a 7mm bolt on the compressor pulley & its vry tight like hell.
    how to open that 7mm bolt to replace the bearing ??
    vitz compressor bearing -1244597
    Reference pictures
    vitz compressor bearing -1244598
    vitz compressor bearing -1244602
    vitz compressor bearing -1244601
    R.I.P. Follow
    shegg4's Avatar
    Mar 2013
    Select City
    705
    123 Post(s)
    9 Thread(s)
    you have to loose compressor and pull it out of engine bay without removing the gas pipes and then you can remove nut and change the bearing otherwise it`s not possible
