Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Like Tree13Likes
Thread: Which one would be a wise buy out of Vitz 1.3L & Vitz 1.0L? (2011 model)
    SaharS's Avatar
    Jul 2013
    38
    Default Which one would be a wise buy out of Vitz 1.3L & Vitz 1.0L? (2011 model)
    My usage: Mostly within Lahore
    Out of City travel: Very less (once in a 3 months)
    I know apparently 1.0L appears to be a better option but people have suggested to me to get 1.3L to be at ease for longer out of city routes whenever required.
    NEED SUGGESTIONS. Thanks
  2. #21
    SaharS's Avatar
    Jul 2013
    38
    Thanks.....why did u get a 1.3L instead of 1.0L? because of long distance driving requirement?
    Quote Originally Posted by Ravager View Post
    take it from someone who has kept both.
    My 1.3l vitz has a lot more power than 1.0l and the mileage is almost the same... 1.3l gives me slightly better mileage.
  3. #22
    SaharS's Avatar
    Jul 2013
    38
    Thank you...Your law i must say is very logical.....does your last line suggest that 1.3l will be equivalent in fuel economy to 1.0l when used till the full limit of 1.0l??
    Quote Originally Posted by levin View Post
    if car weight is same , both should give similar mileage according to my law of certain power required to pull certain amount of weight. 1.3l will only benefit from more power when you reach full limit of 1.0l
  4. #23
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    on paper things look easier,, you have to find a good car in good price that should be trouble free, this is difficult
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
  5. #24
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    techinically yes. smaller and bigger engine produce equal power to pull certain weight. if you increase passengers, mileage drops. if you go near engine red line , mileage drops. if you reduce standard tire psi , mileage drops, if air fuel ratio goes out on engine mileage.. plus so many other factors, like wind pressure, speed, etc etc.
  6. #25
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    Quote Originally Posted by SaharS View Post
    1.0l had a very sad drive. it was really under powered plus i was not getting the fuel mileage i should be getting for sacrificing so much power.
    Drugs cause amnesia, and other things I can't remember
  7. #26
    hasooboy's Avatar
    Feb 2010
    29
    5,401
    81 Post(s)
    3 Thread(s)
    1.0 is really under powered car, as per my observation drive of 1.0 passo is lot better then 1.0 vitz.
    Sent from my Novo7 Venus using Tapatalk HD
    Boy Badnam hua LIANA tery liya
  8. #27
    abzia's Avatar
    Oct 2006
    32
    337
    10 Post(s)
    Thanks a lot for this detailed reply.....could you please elaborate what's KR-FE & SZ-FE?
    These are the engine codes of 1.0L and 1.3L versions ... There is another 1.3L version 2nzfe which comes coupled with AWD train. It has better traction but is a little less fuel efficient
  9. #28
    usman505's Avatar
    Apr 2012
    Rawalpindi
    22
    301
    3 Post(s)
    Thanks....could you please elaborate how can we economize fuel within city through driving style????
    driving with light foot on accelerator provides u with the best fuel economy-do not rev it hard , do not pull it is gears,do not floor the peddle ,like wise that ....
    calm driving is always light on ur pocket ,simple phenomina
  10. #29
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    Quote Originally Posted by abzia View Post
    I have the 2nz-fe vitz, there is not that much mileage difference. i still am getting better mileage than 1.0l
    Expect this mileage from your car
    Local : 10-12 (with AC)
    High way : 14-16 (with AC)
