Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 71
Like Tree4Likes
Thread: Vitz 1KR-FE engine problems
    rehan3777's Avatar
    Jun 2011
    Peshawar
    20
    Default Vitz 1KR-FE engine problems
    Hello all !
    I have a quite experience in vitz because in three year i have changed six vitz ..all were 1000 cc. But model difference. While using vitz 2007 the engine was driven 70000km but in good condition ..i drive it ,no vibration no engine noise ....but when i purchase 2009 model vitz (25000 km driven) but engine was vibration badly..mechanic washed throttle body and it works but vibration was not ended but it reduces.
    Recently i sold 2009 model and purchase 2012 model vitz new shape. Engine is driven 6800km and recently fully maintain .oil etc changed ..throttle body and spark plugs cleaning ..engine is good and giving good milage ...but problem is when engine start .. i feel vibration in interior ...when i open up bonet engine was vibrating. Not in still condition...mechanics says kay itni vibration tu hoti hay..but i m not satisfied yet ..i vil make video of the engine vibration and will upolad in evening...
    But any expert of engine r among u kindly give me advise.
    Sent from my HTC One using PW Forums mobile app
  2. #21
    rehan3777's Avatar
    Jun 2011
    Peshawar
    20
    Guys finaaly i found solution....i jist throw out 1kr 1000cc engine nd now putting 1nz 1500 cc in it...hope i didnt get vibration this time
  3. #22
    mawaisakram's Avatar
    Sep 2009
    35
    7
    Can anyone suggest me a good mechanic for Vitz in Lahore. ? The problem is this that on petrol vehicle pick is very low and missing is also there. So i want a person that can find the exact problem as i have tried a lot of mechanics and they done tuning, plug changed, ring and piston changed etc... but the problem is still there.
  4. #23
    rehan3777's Avatar
    Jun 2011
    Peshawar
    20
    Change yout fuel filter and clean the fuel injectors from toyota sahara motors.
  5. #24
    Sep 2009
    35
    7
    Fuel Filter changed, injectors cleaned from Toyota Cantt motors
  6. #25
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    Quote Originally Posted by amjads98 View Post
    Hello jigzyy. Stp or oem Toyota fuel injector cleaner is the same? I am getting mileage of 11km/l in city. But on high it is around 14. Will these cleaner will help me as I have already clean fuel filter and harmonic fuel injection cleaning. Every time I mix super with hioctane in the ratio of 40 50. I recently switched from shell hilux Ultra 5w 30 oil to Toyota 10w 30. And I am much satisfied with it. Regarding other maintenance of engine I am doing by my self. I am hoping that these cleaner are not harmful for engine. Your reply will be very helpful as you are already using it. Thanks.
    STP is safe for any gasoline engine. You can try that. As per engine oil, always used manufacture recommended. For Vitz, it's 5w-30 but people are using 10w-40 mostly.
  7. #26
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    Quote Originally Posted by mawaisakram View Post
    Use this small bottle : Fuel Cleaner by STP® | Complete Fuel System Cleaner Get it from Hyperstar, and pour this in the fuel tank which should be at least 70% full.
    and then use couple of times with next fill ups : Gas Treatment by STP® | The Original STP® Fuel Additive also available at hyperstar. Should make a difference.
    Lastly use Shell Helix Ultra 5w-30 (it's costly but good), or any other companies 5w-30 which is recommended for vitz & put a genuine Toyota Oil Filter.
  8. #27
    ahmedk06's Avatar
    Jul 2009
    39
    569
    10 Post(s)
    possibly air circuit problem, your air filter is leaking air, also check for any broken engine mount
  9. #28
    Sep 2009
    35
    7
    @jigzyy: Ok i will try to use this filter today. and m already using helix ultra 5w... @ahmed: I have checked air filter leakage, but its fine. I was also thinking that may be it is due to air leakage.
    Dear can anyone knows any excellent mechanic so that he may physically check it and it will be very easy for him to trace the acutal bug
  10. #29
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    Quote Originally Posted by rehan3777 View Post
    Dear rehaan. Have you changed your engine. How much alteration you have done. 1krfe engine have cvt transmission but 1nzfe often comes with manual transmission and rare automatic.
    Final and most important thing how you feel the drive now. Any issues or no issues at all? I want also change my engine with 1nrfe. Which is cvt 1.3 and very economical then all other engines. Hope to get your answer soon. Thanks.
  11. #30
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    Did you ever change the cvt oil ?
    Apart from pakwheels, my blogs can be also be viewed at http://tajziat.blogspot.com/
  12. #31
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    Quote Originally Posted by bilalahm View Post
    Yes, and used toyota cvt oil. Is it something to do with engine change query???
  13. #32
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    People usually do not change it, and it results in inferior response from the tranny and hence the drive quality is effected :-)
  14. #33
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    Never heard this before. My car drive is excellent. The only problem is fuel consumption is very high in city. 10 km per liter. But on highways its 17. 1krfe engine is not giving good consumption in city thats why I wanted to switch my engine to 1nrfe. If anyone had experience please share. Thanks in advance.
  15. #34
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    test the ECU fuel trims, AFR sensor reading and MAF reading before you swap engines, you should also check the engine mechanical health before saying yes to swap - you might end up in a bigger mess.
  16. #35
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    Xulfiqar bhai. The engine health is fine. But 99% of driving in city and having a bad fuel consumption is too much. You know the petrol prices are very high. And every fifth day I am in the row of filling my tank with high octane and super. Almost 20000 per month. I just wanted to reduce it to like 13000. Why swapping engines are not recommended if I buy the engine with wiring and ecu. Your advise will be highly appreciated as you are most experience person. Thanks
  17. #36
    ibadaslam872's Avatar
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    Check your engine mounts maybe?
    Sent from my GT-S5660 using PW Forums mobile app
    Under the Coconut tree
  18. #37
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    Quote Originally Posted by LIANARULES View Post
    Engine mounts are fine. Replaced one last month. Tyres are bigger then normal. 195 are installed rim size are 14. Maybe this the problem?
  19. #38
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    Was about to ask this question :-), you cannot expect such a tiny engine to drag those 195's and not protest about it, in this case by gulping in more fuel. You need to switch to a reasonable size ASAP, 165's aren't easily available in 14 easily so at least get it to 175 and it would make things very different for your fuel situation. Also are the rims stock or aftermarket ?
  20. #39
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    Can you check that you have the correct plugs i.e. K20HR-U11 running with the exact gap of 1.1 mm ? Also do try to install the normal copper one's and not the iridium, yes the cars that are imported come
    with iridium but the reason is that labor costs are insane over there and those last really long, but copper would be better in short term just throw them away at
    25K kms and you are good to go
  21. #40
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    Is the CAT removed ? Have you checked that the intake is not taking excess air from any leaks / cracks in the plastic ? Which brand of air / fuel filters are you using ? Ever changed the fuel filter ?
