Results 1 to 19 of 19
Like Tree3Likes
  • 1 Post By arehman5962
  • 1 Post By versatile_tuners
  • 1 Post By rizkhan2010
Thread: Vitz 1.0 2008 engine check light (yellow sign)
    ozzeyy's Avatar
    May 2010
    27
    78
    Default Vitz 1.0 2008 engine check light (yellow sign)
    hi everyone.
    i bought vitz 2008 and just changed transmission oil .engine oil and filter...
    and after driving a few kms my car is showing yellow light..,
    Any solution?
    regards
    waleed911's Avatar
    Sep 2011
    485
    16 Post(s)
    Probably some sensor is causing that... It may be the MAP sensor but you can only be sure after you have diagnosed the car with an OBD 2 scanner...
    Enercon has one and so does Toyota...
    Cheers
    Driving is not about going from point A to point B, it is the point...
    ozzeyy's Avatar
    May 2010
    27
    78
    Thanx Waleed
    is there any diagnose center to solve this..
    Please mention if it is in the locality of Islamabad.
    regards
    waleed911's Avatar
    Sep 2011
    485
    16 Post(s)
    Enercon in G 10 markaz near Shell station...
    They will charge you 1000 for a scan and rectification is apart from that...
    Cheers...
    ozzeyy's Avatar
    May 2010
    27
    78
    OK
    Thanx Alot.
    ozzeyy's Avatar
    May 2010
    27
    78
    Quote Originally Posted by waleed911 View Post
    Cheers...
    hi..
    i went there , it was (P1589 acceleration sensor learning value) problem..
    they could'nt resolve it. they said if there is a problem in wiring then we cannot check that one.
    they will charge more for new sensor.
    Huzaifa_Khalid's Avatar
    May 2013
    Rawalpindi
    2,813
    37 Post(s)
    Quote Originally Posted by ozzeyy View Post
    hi..
    Go To Any Toyota Service Center They Will Resolve The Problem Easily.
    Like My Page Please: https://www.facebook.com/BabuJeeKaThullu?ref=hl
    ozzeyy's Avatar
    May 2010
    27
    78
    Quote Originally Posted by Huzaifa_Khalid View Post
    Thanx Huzaifa
    do you know how much they charge for it?
    May 2013
    Rawalpindi
    2,813
    37 Post(s)
    Thanx Huzaifa
    Minimum 2000
    May 2013
    Rawalpindi
    2,813
    37 Post(s)
    Thanx Huzaifa
    I Have Another Solution For You, It Might Work.
    ozzeyy's Avatar
    May 2010
    27
    78
    Whats that??
  12. #12
    May 2013
    Rawalpindi
    2,813
    37 Post(s)
    Whats that??
    Disconnect The Battery Terminals For 10 Mins And Then Reconnect Them Back After 10 MINS, This Procerdure Resets Ur Car's ECU. This May Solve Your Issue.
  13. #13
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    check air filter sensor while replacing filter they might have unfixed it
  14. #14
    waleed911's Avatar
    Sep 2011
    485
    16 Post(s)
    These cars are too much sensor dependent... Your best bet is taking it to Toyota and replace the sensor... (Which I presume is the throttle position sensor inside the cabin of the car, or the one on the throttle body but I can be wrong since I am no expert here)...
    The error code is generic... Remedies are expensive if not thorough...
    Cheers...
  15. #15
    arehman5962's Avatar
    Oct 2013
    Peshawar
    28
    41
    AOA i have got the same problem wid my 1.3 vitz. have your problem been solved.ozzey reply will be highly appreciated. Thanks
  16. #16
    Oct 2013
    Peshawar
    28
    41
    hi..
    Buddy i m having vitz 2008 1.3. I was having the same problem but i got it solved from peshawar. I got the error cleared from many scanner including toyota showroom but it reapeared again and again then i got a person in pesh. Actually there is no problm in the car coz he told me it just require the original vitz software and the mileage also improved. Feeling relaxed. P1589 acc sensor learning value error
  17. #17
    Site Banned Follow
    versatile_tuners's Avatar
    Mar 2014
    7
    hi..
    your problem will be solved in ten minute's..
    want to solve it?
  18. #18
    Site Banned Follow
    Mar 2014
    7
    hi..
    your vehicle's need relearning Of Acc Sensor it is the minute or 2 job to resolve it Pm for more detail's...
  19. #19
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    check engine light /warning light comes as a warning of some problem in engine bay. which means that warning light is NOT a problem in itself. Instead its a symptom of another problem. So do not suppress the WARNING before you have resolved the relevant problem.
    Battery ki taar alag kr dena ya sirf OBD scanner se erase krwa dena may not help. Because an unresolved problem would trigger the WARNING LIGHT again.
    Let me give you one analogy to explain my point. Suppose there is a FIRE in a building....and fire-warning alarm starts sirens. What would you do ??? kill the alarm... or... kill the fire ??
