Results 1 to 2 of 2
Thread: Sensor Issue vitz 1.0 2008
    ozzeyy's Avatar
    May 2010
    27
    78
    Default Sensor Issue vitz 1.0 2008
    Showing this error on device (p1589 acceleration sensor learning value)
    if the sensor is exhausted then from where to buy new sensor of the same kind and what's the cost??
    anyone can help in this regard?
    Any specialist Mechanic in ISB? If yes plz guide.
    Thanx
    Regards
    Morani's Avatar
    Nov 2008
    33
    348
    2 Post(s)
    First of all, track down the physical location of the sensor. see if the connector pins are rusted. Hopefully it should clear after reconnection.
    Sensor don't exhaust so quick...
    Google says that in some cases the root lies with the TPS sensor. See if reconnecting it.. If you don't know the location of TPS, there's a dedicated thread on pakwheel on TPS adjustment. Look it up.
  3. 17-09-2013, 01:59 PM
    565
    Newbie
