Results 1 to 3 of 3
Thread: Fuel system Toyota Vitz
    waleed911's Avatar
    Sep 2011
    487
    16 Post(s)
    Default Fuel system Toyota Vitz
    Salam everyone...
    As the title suggests, I have a problem with my fueling system (or I think I have)...
    I swapped a 1nzfe and no modifications were done to the fuel system...
    Also, after tuning from Enercon, I can smell petrol while driving and for some time when parked... (Do I go to Toyota and have them check it?)..
    No error codes are recorded currently...
    If I had to upgrade the fuel system... What would you guys suggest?..
    Thanks and Cheers...
    Driving is not about going from point A to point B, it is the point...
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Quote Originally Posted by waleed911 View Post
    Salam everyone...
    Hmmm what mileage u r getting?? it sounds like ur vitz 1nz-fe 1.5L swapped Engine is running rich too rich
    waleed911's Avatar
    Sep 2011
    487
    16 Post(s)
    Quote Originally Posted by hameeds01 View Post
    Found the problem... Culprit was a pipe... I ll see if it holds in the morning as well as it leaks when the car is cold...
    But still... Do I change the fuel system or something?... I am getting good mileage out of it... Using 10 liters of Hi Octane in a full tank...
    Cheers..
