Results 1 to 4 of 4
Thread: Vitz Tyre Size change.
    jh278138's Avatar
    Sep 2013
    6
    Default Vitz Tyre Size change.
    Hello,
    I recently got new tyres for My Toyota Vitz 2009. Previously, they were 165/70/r14.
    I replaced them with Michelin Energy 185/70/r14.
    Basically after the change my car requires more throttle when it approaches 100km/h and at 120km/h smell of a rubber comes. Drive has become heavy.
    NOTE: I haven't changed the stepheny(rim).. its the same steel black colored.
    Can anyone suggest, how to fix this.
    Regards,
    Junaid
    goraya111's Avatar
    Sep 2013
    Gujranwala
    25
    27
    Check the alignment and wheel balancing
    CutePoison's Avatar
    Nov 2010
    855
    Sounds just like a side effect of wide tyres. They look cool and apart form that ruin everything.
    Buying a JDM import is too much risky. Reversed Meter, weak engine may b. Thanks to local dealers who just wont earn halal
    jh278138's Avatar
    Sep 2013
    6
    Alignment is perfect..
