Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Like Tree2Likes
Thread: Weird Vitz Horn Issue
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    Exclamation Weird Vitz Horn Issue
    Lately, I have been experiencing Weird issue with my vitz horn. If I turn the steering to left (at least 90 degree) it'll honk then, but if it's straight OR turned right (sometimes works on the right too) than it will not honk, what could be the reason, any experience what would it cost?
    Thanks!!!
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Horn coil is broken which is under steering wheel
    Sent from my HTC Sensation 4G with Beats Audio using PW Forums mobile app
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    Quote Originally Posted by asad1 View Post
    What would Toyota cost if I get it fixed from them & what would be the cost from outside technician? What are rcommendations?
    yasirengg's Avatar
    Jun 2006
    Bahawalpur
    34
    354
    2 Post(s)
    Toyota will replace the disc under steering it will cost 10K plus get the cable solder from some good electrician it will cost around 1000Rs.
    rustam54's Avatar
    Aug 2006
    1,004
    113 Post(s)
    That coil is called clock spring.
    Please donot attempt to get it repaired if your vehicle has an AIRBAG (Most likely). This may lead to very dangerous situation if your repaired clockspring shorts out in fututre.
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    Quote Originally Posted by rustam54 View Post
    That coil is called cloock spring.
    So the only opiton I have left with is to either replace the clock spring or leave it alone, is it right ?
    rustam54's Avatar
    Aug 2006
    1,004
    113 Post(s)
    Yes. My advise would be to get a used one from market. I have heard, that toyota's clocksprings are not that expensive.
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    I was thinking the same, to get from kabariya etc. First I'll check it from Toyota what they are going to charge, and then I'll search market for it. I hope it's not that expensive :s
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    There is a member selling vitz steering wheel. Search previous threads.
    Otherwise install a push button on pillar (New Khan bus style)
    The best car safety device is a rear-view mirror with a cop in it.
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    Quote Originally Posted by waqar19 View Post
    Lol okay, let me search.. Help me find too if you get it first
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
  12. #12
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Its for rs 3500
    Close your eyes and grab it asap
  13. #13
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    Its for rs 3500
    Lol, thanks for the link, I have messaged him if the steering rack is still up. I hope this steering doesn't have clock spring issue.
  14. #14
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    As said - do not attempt to repair the clockspring and make sure its centered when you install it. If its off centre it will break again as the steering goes to full lock. (If your car as evidence of steering rack replacement/repair - it can be assumed the mechanic did not centre and lock the steering before undoing the pinchbolt of the column.
    Toyota made generic clocksprings and used them in all cars of same production era.
  15. #15
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
    Thank you @Xulfiqar bhai for the tip. I went to "Auto Plaza" in Multan and found a replacement in 2200. Now the horn is working again Thank you @waqar19 for the thread.
  16. #16
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
  17. #17
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
  18. #18
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
  19. #19
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
  20. #20
    jigzyy's Avatar
    Feb 2012
    Multan
    150
    5 Post(s)
Tags for this Thread
