Results 1 to 12 of 12
Thread: Continuosly sound like knocking Vitz 2008 1.0
    ozzeyy's Avatar
    May 2010
    27
    78
    Default Continuosly sound like knocking Vitz 2008 1.0
    hi everyone
    i am facing a problem on my vitz 2008 while driving when the car changes its gear if i slightly touch an accelerator for a low speed driving a continuous sonud is coming like knocking(tik tik tik) . Dont know what to do?
    My mechanic says its a patrol problem i should use High Octane.. i have tried but the sound is still same.
    Any Solution
    Regards
    umarkhan1's Avatar
    Nov 2010
    Sargodha
    2,312
    6
    8
    51 Post(s)
    4 Thread(s)
    Auto or manual??
    Sent from my iPhone 4S using PW Forums mobile app
    Just Do It Your Self!!!!!
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Quote Originally Posted by umarkhan1 View Post
    Auto or manual??
    Car changes gear so its obviously auto.
    The best car safety device is a rear-view mirror with a cop in it.
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    Knocking is a sharp metallic sound produced in the internal combustion engine due to prior ignition of fuel. High octane fuel dont produce knocking. Only poor quality fuel do so.What mechanical work u have done recently????
    where from you refill petrol??
    what was quantity of high octane fuel??
    FarhanAnwarKhan's Avatar
    Sep 2012
    Rawalpindi
    23
    2,633
    67 Post(s)
    5 Thread(s)
    This is a common problem in Vitz...the knocking whatever u try that sound will still be there
    Sent from my HTC Rhyme S510b using PW Forums mobile app
    JDM Always 2 STEPs AHEAD..........
    ozzeyy's Avatar
    May 2010
    27
    78
    Quote Originally Posted by Ishtiaq778 View Post
    i have just change some regular things like engine oil and filter and transmission oil at 50000kms. i use to have it from shell at jinnah super. quantity was 30 litres.
    ozzeyy's Avatar
    May 2010
    27
    78
    Quote Originally Posted by ozzeyy View Post
    Does knocking harmful for engine?
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Yes continuous knocking is extremely dangerous. Pistons will be busted soon.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    ignition timing needs to be adjusted. any chance CNG kit is installed & removed either way. Knocking is due to advanced ignition timing
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    umarkhan1's Avatar
    Nov 2010
    Sargodha
    2,312
    6
    8
    51 Post(s)
    4 Thread(s)
    Quote Originally Posted by capsat View Post
    How ignition timing is adjusted on dizzy less engine???
    ozzeyy's Avatar
    May 2010
    27
    78
    Thanx capsat.
    but can i do it by my self or i should visit to mechanic.
    Regards
  12. #12
    khalid443's Avatar
    Dec 2014
    43
    Go to mechanic
