Results 1 to 4 of 4
Thread: Help needed Toyota vitz engine light 2006
    shayan0321's Avatar
    Dec 2012
    22
    Default Help needed Toyota vitz engine light 2006
    hi guys i have a toyota vitz 2006 auto 1.0 for about past year.. Always used as a secondary or third car at home.. From past few days the engine light of my car keeps turns on.. Have checked with my local mechanic and he says all engine oil nd fluids are in order.. Mileage of car is 69000 and the drive is also perfectly smooth without any issues but the engine light turns on after the car is driven for around 5-10 mins.. Pls advice me what the issues can be and if possible the best shop where i could get my car checked from preferably which showroom workshop should i take it to be checked.. Kindly advice if you have any knowledge about the issue. Thanks
    waleed911's Avatar
    Sep 2011
    485
    16 Post(s)
    Have it scanned... And then, if necessary, tuned... Go to a good tuning shop and not some roadside mechanic...
    Cheers...
    Driving is not about going from point A to point B, it is the point...
    ozzeyy's Avatar
    May 2010
    27
    78
    Quote Originally Posted by shayan0321 View Post
    hi Bro
    i am having the same issue with my vitz 2008 1.0 , i had checked with enercon but they could not find it and one of my friend has suggested me to visit toyota service only they can solve it so i must say you may visit toyota.
    regards
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,578
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Post
    so u trust mechanic for maintenance alibi ? do you have track record of Fluid & Filter changes of the car. Hookup to diagnostic computer get a print out share the fault codes you get. Please do not attempt to reset ECU by removing terminal from battery, it may remove the check light but not the reason of fault
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
