Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By sirdneo
Thread: vitz automatic to manual
    saadkamal's Avatar
    Jun 2008
    27
    120
    Default vitz automatic to manual
    salam
    brother i wanted to ask that any has converted auto vitz to manual .....if yes then what was the procedure whate things have to be chnged and what was the difference in pickup mileage and over all performance....
    possitive enforcers plzz help out thnx
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    performance will be outrageous but swapping isnt that easy plus it will cost 40k minimum as manual gear box setup is pretty rear
    saadkamal's Avatar
    Jun 2008
    27
    120
    thnku bro actualy i have a bolt to bolt swap ready from another vitz from another vitz
    saadkamal's Avatar
    Jun 2008
    27
    120
    some more experts plz ?
    sirdneo's Avatar
    May 2013
    84
    4 Post(s)
    I Have manual vitz, and its drives is awsome, you can get up to 100 in no time. But as far as conversion is concern, I say big no to it. Most of Utad Type mechanics dont have any idea what they are doing and you will ruin your car.
    Also I guess ECU b different hota hy for manual vitz which will make things more complex , so never think of it in Pakistan.
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    You would have to change the ECU because ECU is the one who is incharge there. Also you would have to change your gear shifting lever. Gear box or transmission is a must. Plus some wiring modifications. That is all on very detailed you may want to change your cluster as it has some extra lights. If i were you I would stay with default because it would be much hastle with decreased re sale value and constant problems because of alteration done by Ustaad Maja and Sheeda Electrician.
    93 Accord CB7 (Sold) / 2005 CL7
