Removed CAT con after drivin 70k kms, and after that installed additional DHOLKI to reduce noise whhich comes after CAT removal...toyota vitz chocked cat removal and noise solution after cat removal -1277443toyota vitz chocked cat removal and noise solution after cat removal -1277444toyota vitz chocked cat removal and noise solution after cat removal -1277445toyota vitz chocked cat removal and noise solution after cat removal -1277446
Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277474
toyota vitz chocked cat removal and noise solution after cat removal -1277447toyota vitz chocked cat removal and noise solution after cat removal -1277448toyota vitz chocked cat removal and noise solution after cat removal -1277449toyota vitz chocked cat removal and noise solution after cat removal -1277450toyota vitz chocked cat removal and noise solution after cat removal -1277451toyota vitz chocked cat removal and noise solution after cat removal -1277452toyota vitz chocked cat removal and noise solution after cat removal -1277453toyota vitz chocked cat removal and noise solution after cat removal -12774541) Car on dock..
Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277469
2)CAT con opened and visible by opening joint just under engine after exhaust manifold..
Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277476Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277475Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277477
3)Brocken CAT con.
Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277470Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277472Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277473
4) DHOLKI installation after CAT removal to reduce BHARRRR BHARRRR PHiTT PHiTT noise of Vitz
Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277478Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277479Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277480Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277483
5) Place where extra dholki installed just close to Secondary dholki under car cabin
6) And Alhamdulillah my car is silent just as new and regained its lost power and acceleration which it had 4,5 years back...
Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277504Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277505Toyota Vitz chocked CAT removal and Noise *SOLUTION* after CAT removal -1277507
