Page 1 of 6 123 ... LastLast
Results 1 to 20 of 107
Like Tree62Likes
Thread: Toyota Vitz choked cat removal and noise solution after cat removal
    Ahkhan89's Avatar
    Jul 2010
    86
    8
    2 Post(s)
    Cool Toyota Vitz choked cat removal and noise solution after cat removal
    Removed CAT con after drivin 70k kms, and after that installed additional DHOLKI to reduce noise whhich comes after CAT removal...toyota vitz choked cat removal and noise solution after cat removal -1277443toyota vitz choked cat removal and noise solution after cat removal -1277444toyota vitz choked cat removal and noise solution after cat removal -1277445toyota vitz choked cat removal and noise solution after cat removal -1277446
    1) Car on dock..
    toyota vitz choked cat removal and noise solution after cat removal -1277474
    toyota vitz choked cat removal and noise solution after cat removal -1277447toyota vitz choked cat removal and noise solution after cat removal -1277448toyota vitz choked cat removal and noise solution after cat removal -1277449toyota vitz choked cat removal and noise solution after cat removal -1277450toyota vitz choked cat removal and noise solution after cat removal -1277451toyota vitz choked cat removal and noise solution after cat removal -1277452toyota vitz choked cat removal and noise solution after cat removal -1277453toyota vitz choked cat removal and noise solution after cat removal -1277454
    2)CAT con opened and visible by opening joint just under engine after exhaust manifold..
    toyota vitz choked cat removal and noise solution after cat removal -1277469
    3)Brocken CAT con.
    toyota vitz choked cat removal and noise solution after cat removal -1277476toyota vitz choked cat removal and noise solution after cat removal -1277475toyota vitz choked cat removal and noise solution after cat removal -1277477
    4) DHOLKI installation after CAT removal to reduce BHARRRR BHARRRR PHiTT PHiTT noise of Vitz
    toyota vitz choked cat removal and noise solution after cat removal -1277470toyota vitz choked cat removal and noise solution after cat removal -1277472toyota vitz choked cat removal and noise solution after cat removal -1277473
    5) Place where extra dholki installed just close to Secondary dholki under car cabin
    toyota vitz choked cat removal and noise solution after cat removal -1277478toyota vitz choked cat removal and noise solution after cat removal -1277479toyota vitz choked cat removal and noise solution after cat removal -1277480toyota vitz choked cat removal and noise solution after cat removal -1277483
    6) And Alhamdulillah my car is silent just as new and regained its lost power and acceleration which it had 4,5 years back...
    toyota vitz choked cat removal and noise solution after cat removal -1277504toyota vitz choked cat removal and noise solution after cat removal -1277505toyota vitz choked cat removal and noise solution after cat removal -1277507
    <....MaVericK....>
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    you just dumped about USD 100/- worth of platinum, palladium etc on the ground. And to make it worse you just completely messed up your car's ECU mapping. Its designed to fuel the engine keeping in mind that the engine also has a working cat converter. The little sensor after the cat actually has a job.
    Ahkhan89's Avatar
    Jul 2010
    86
    8
    2 Post(s)
    dude thats why i did it after drivin 70k kms, when i baught that was 16k on odo meter...
    i tried my best to save CAT , but i cant, nd btw platinum ka CAT in cars me nae aata wo mehngi cars ka hota hay, is me Ceramic CAT aata hy..
    nd rahi bat ECU ,engine ki, wo tab masla hota hay jab aap open pipe rehnay dain , i installed that extra DHOLKI which provides necessary back pressure. which i think not bad for engine..
    <....MaVericK....>
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    every catalytic converter in the world has those metals - the ceramic core is plated with it internally. It doesnt matter if the car is a rolls royce or a cheap as chips vitz
    The post cat sensor is not looking for backpressure. Its looking for O2 content. The O2 sensors are also wear out and tune up items but no-one in Pakistan replaces them as they are quite expensive - Toyota AFR sensors are about 300 dollars aka Rs 30,000/- and the o2 sensor is about USD 80/- or about Rs 8000/-
    These are usually worn out at every 100,000 kms - or depending on drive style or poisoning by silicone or coolant or leaks etc.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    If you closely look at the broken cat ceramic core with a magnifier you may find some shiny metallic particles like "glitter" that is the precious metal Im talking about - its far more expensive than gold.
    Hesab_Magsi's Avatar
    Aug 2010
    Quetta
    26
    1,739
    31 Post(s)
    Quote Originally Posted by Ahkhan89 View Post
    Back in 07 when i had vitz and had this same problem,only one guy in khi knew about CAT problem in these cars.he did remove it from my car but didnt knew about this dholki system,used to hate that noise after CAT removal.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    I did the same installed secondary dholki in my car after removing CAT
    Sent from my HTC Sensation 4G with Beats Audio using PW Forums mobile app
    Ahkhan89's Avatar
    Jul 2010
    86
    8
    2 Post(s)
    Quote Originally Posted by asad1 View Post
    yup, thats the only solution for that annoying phit phit noise frm vitz..
    <....MaVericK....>
    Ahkhan89's Avatar
    Jul 2010
    86
    8
    2 Post(s)
    yar ab kia ho skta hay jb uski waja se meri gari accelerator he nae le rae thii, i know CAT is gud, thats why i did it after 70k, when i felt k meri gari bilkul he zor nae le rahi, yaha k log to gari khareedtay saar he farz samj k turwatay hain...:p
    <....MaVericK....>
    vman's Avatar
    Aug 2010
    30
    23
    Wrong -
    Catalytic converters:
    Catalytic converters are fitted to both petrol and diesel engines and contribute to the reduction of harmful exhaust gases, such as hydrocarbon (HC) and carbon monoxide (CO).
    The exhaust gases pass through a honeycomb brick, which is coated with noble metals (i.e., platinum, palladium and/or rhodium), which convert undesirable hydrocarbons and carbon monoxide to carbon dioxide and water, and nitrogen oxides to nitrogen and water.
    I Don't have Dreams, I have Goals.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    when you buy a certain car - you buy its maintenance too - throwing stuff away because its too expensive to replace is perfectly fit for the saying
    "jab haathi paalte hain to darr bhi ooncha karte hain"
  12. #12
    bango's Avatar
    Jun 2009
    Select City
    8,055
    57 Post(s)
    Was there a secondary O2 sensor in the car after the cat converter?
    A Post-Wh0re is a user who's only aim in life is to increase his post count. He/she gets off by receiving likes and mentions, and considers his post count a medal on his skinny chest. A post-Wh0re is the human equivalent of Chihuahua..bickering pointlessly, effortlessly, permanently.
  13. #13
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    whats the point of 3 mufflers?. might as well put straight pipe if cat is removed
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
  14. #14
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    Giving your car a high-speed run on highway/motorway once in a while prevents major surgeries like these.
  15. #15
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    Quote Originally Posted by rizkhan2010 View Post
    This should be quoted to Govt. we need place to keep cars fixed and we don't like breaking speed limits on motorway.. from people of Pakistan
  16. #16
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    Quote Originally Posted by levin View Post
    lolz... true that
  17. #17
    hash4u's Avatar
    May 2005
    38
    24,366
    18
    404 Post(s)
    13 Thread(s)
    13
    the solution is at government level
    to provide us with cleaner better octane fuel
    someone i know bought a new civic.the refused to go uphill with load
    the car was just few thousand kms driven
    diagnosed choken cat converter.company cleaned it and installed it back
    not everyone can afford hi octane
    u cant clean cat converter with every oil change can u
  18. #18
    Ahkhan89's Avatar
    Jul 2010
    86
    8
    2 Post(s)
    haha yaar its not a hathi, its a normal economical car nd i baught it for economy, i knoe=w i can get a new KABLI CAT in 6,000rs for my car but faida????
    humare mulk ki fuel quality aisi hay k 10k k baad phir blockage shuru ho jana hy...
    <....MaVericK....>
  19. #19
    Ahkhan89's Avatar
    Jul 2010
    86
    8
    2 Post(s)
    bcz vitz's engine 1kr makes loud noise when we remove CAT
    <....MaVericK....>
  20. #20
    Ahkhan89's Avatar
    Jul 2010
    86
    8
    2 Post(s)
    Quote Originally Posted by bango View Post
    yes !! just after CAT con
    <....MaVericK....>
Tags for this Thread
