Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Like Tree1Likes
Thread: Need help for vitz
    ali_sh's Avatar
    Oct 2013
    16
    Default Need help for vitz
    AOA,
    I have vitz 2004 model (old shape) 1000cc, auto, Petrol. From past few months i am facing a problem related to its starting.
    Its starts on 2 short selfs (ignition) OR 1 long self.
    But if i start it just after turning it off it starts normally. However after starting it in any condition it runs smoothly.
    The steps i have taken place to resolve the issue are:
    1. Fuel injectors cleaning (Ultra sonic bath cleaning)
    2. Fuel pump changed
    3. Fuel filter changed
    4. Spark plugs/air filter changed
    5. Coolant temperature sensor changed
    6. Air flow sensor changed
    7. New battery (AGS GL-50)
    8. Fuel Pressure Regulator changed
    But the issue is still there. I don't know what to do now to get rid of this problem. I have already spent much on this but all in vain.
    Hope someone can help me.. Thanks!!
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Check fuel pressure regulator and also clean fuel rail.
    Never loose hope in life,every step gives u something.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    ..in continuation to suggestion by @argtr65 - also check for electrical connection to FPR inspect carefully & check for ground.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Rhagvan's Avatar
    May 2013
    120
    i also have vitz 2003 is ne bhi meri bohat jan khai hai yaar , ap ki jo problem hai wo valves ki waja se hai is ka cheap kam valves grind karna hai but its not reliable agar car long time use k liay rakhni hai to new japani valves dalwa lo warna mechanic se lut tay raho *** koi bolay ga yh karlo koi bolay ga yh karlo faida nahi hoga
    ali_sh's Avatar
    Oct 2013
    16
    Thanks for ur suggestions @argtr65, @capsat
    Can you please tell me where this fuel pressure regulator is located in vitz 2004?
    Although i still doubt about it, as i have already mentioned above, if i start the car within 1~2 mins after shutting it of it starts normally, but after this time period, it takes longer self or 2 short selfs. If there is some problem in the regulator i think it should perform the same in both conditions. What do you say?
  6. 24-10-2013, 01:17 PM
    PakWheeler
  7. #6
    ali_sh's Avatar
    Oct 2013
    16
    @Rhagvan
    I have recently got the valves and the tappets checked, and according to the mechanic the tappets were fine. And there is only starting problem, once it starts its not even shaky irrespective of cold or hot weather conditions too...
  8. #7
    ali_sh's Avatar
    Oct 2013
    16
    http://www.ivok.com/image/cache/data...9--500x500.jpg
    Are you talking about this regulator? I know its in the fuel filter assembly. Is there any easy method i can check it at home? @capsat .... as u have said check for the electrical connection to the FPR, i don't remember that any wire going to this part in my vitz.
  9. #8
    ali_sh's Avatar
    Oct 2013
    16
    taking @Xulfiqar in loop..
  10. #9
    ali_sh's Avatar
    Oct 2013
    16
    Also, can someone plz confirm that the fuel pumps runs with the engine cranking and not on the On position (where the power windows or the meter lights comes up). Like in my other car honda city i have checked that the fuel pump pre runs before the engine starting for about 3~5 secs. But in my vitz its not the case, the fuel pump gets the power along with the self.
  11. #10
    ali_sh's Avatar
    Oct 2013
    16
    bump!!
  12. #11
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Need help for vitz -1287956Need help for vitz -1287957
    the VITZ / YARIS fuel system - illustration for information from service manual
  13. #12
    ali_sh's Avatar
    Oct 2013
    16
    @capsat
    Thanks for sharing the detailed diagrams. I have got the pressure regulator and i am going to replace it tonight. It makes sense that the pressure regulator might b faulty, so i am going replace it too.. High hopes that it will solve my problem. I'll definitely share the results after changing it. *fingers crossed*
  14. #13
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    check that FPR by actually checking the pressure at the fuel rail. Replace if necessary and retest.
    The toyota fuel pump circuit only works while cranking and when the engine registers more than 400 rpm on the crank sensor or idle speed airflow at the MAF depending on the type of system being utilised. Honda activate the pump for 2 seconds before cranking like most other car manufacturers.
  15. #14
    ali_sh's Avatar
    Oct 2013
    16
    Thanks @Xulfiqar for your input.
  16. #15
    ali_sh's Avatar
    Oct 2013
    16
    @capsat , @Xulfiqar
    Ok i have changed the Fuel Pressure Regulator but unfortunately the problem still exists
    Before changing it i have checked the fuel pressure by disconnecting the fuel in-let pipe connecting to the fuel injectors rail.
    The fuel pressure was good, as in the bottle quickly filled, but one thing i noticed it that while cranking the fuel started coming out but stopped for a second, like there was a one second gap in the fuel supply while cranking it.
    However i haven't tested it after changing the FPR. I don't know if it is normal or what.
    What should be the next step now?
  17. #16
    ali_sh's Avatar
    Oct 2013
    16
    is there any possibility that my Crankshaft Sensor is going bad?
  18. #17
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Post
    after changing the assy please test the car and post results post picture of changed items for reference.
  19. #18
    ali_sh's Avatar
    Oct 2013
    16
    @capsat
    After changing the FPR there is a very sligh improvement. At morning it started as always in 2nd time but it started in 1st time when i started it after my office, though it took a long ignition but however it managed to start on the 1st time.
    I took very few pics as my hands were all filled with petrol at the time of changing it.
    for reference pics are attached:
  20. #19
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by ali_sh View Post
    @capsat , @Xulfiqar
    umm you checked pressure by flow of fuel?
    which calculation did you apply?
    btw the test the fuel pump power circuit with a test lamp while cranking - if you see it go off for a second you have a problem in the circuit opening relay. Mostly seen in cars with "fudged immobilisers" or bad ignition circuit.
  21. #20
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    @capsat
    is that actually new or a used replacement? and to test pressure you need a pressure gauge.
