Page 2 of 2 FirstFirst 12
Results 21 to 21 of 21
Like Tree2Likes
Thread: Engine oil suggestion for Toyota Vitz 1L, 2010
    aakhan85's Avatar
    Oct 2008
    31
    26
    Default Engine oil suggestion for Toyota Vitz 1L, 2010
    Hiya fellows,
    I have a Toyota Vitz, 2010-model, 1L, which has been driven around 67000km approximately. I'm looking to find a brand and type of engine oil that will be best for the car. After having read through various threads here about engine oils, I'm confused about which one I should go with. People here have suggested Shell, Caltex, Zic, Mobi, and others, which only adds to my confusion.
    So, I wanted to ask simply: Is Zic 0W a good choice for the engine? Or should I go for Zic A+?
    Also, if I use either of the Zic oils I mentioned, what should be an safe drain interval? After how many KMs should I change the oil?
    Your precious advice will be highly appreciated.
    Many thanks.
    Cheers,
    Ayaz
  2. #21
    Xavierl's Avatar
    Oct 2012
    66
    2 Post(s)
    Quote Originally Posted by aakhan85 View Post
    After trying both 0w and A+ versions of Zic, I went with the 10w30 Toyota Japanese Tin can oil. I have been using it for the past two years now without any complaints. I enjoy the drive of the car.
    How is the fuel efficiency compared to ZIC? And where did you buy it from? I am also having trouble locating dealers that sell original oils. Also, isn't 10W a bit too thick for a Vitz engine?
