Results 1 to 9 of 9
Thread: Toyota Vitz AC Compressor Sound Issue
    websiterdesigner's Avatar
    Feb 2012
    Gujranwala
    9
    Default Toyota Vitz AC Compressor Sound Issue
    Hi Buddies,
    I have Toyota Vitz 2005.My car is giving sound when i start it.I checked it buy a local car ac mechanic.He told me that it is AC Compressor PULLI or Barrange sound.He said me that you have to change the AC Compressor of it and we will install TOYOTA COROLLA Ac Compressor.
    Please tell me any other solution or guide me better.
    Thanks!
    s.ahmad.zaidi's Avatar
    Sep 2013
    23
    12
    I once had the similar problem with my Mira and i discovered my Compressor oil faulty and the belt of conpressor was giving that voice. Please tell what happened to your car.
    manobilla16's Avatar
    Oct 2008
    33
    123
    3 Post(s)
    a cousin of mine had 2005 vitz and had the same issue. what i have been told my him is that not to use any other compressor other than OEM, since its a sensor based compressor and of corolla is that of clutch based. so do check before moving forward. and of compressor pully bearing is faulty u can get it replaced with no issue but if compressor bearing is faulty compressor needs to be changed.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Getting original bearing isba headache now a days as they dont last long and will cost atleast 1500
    Vitz ac compressor is pretty expensive but u should not go for alterations 2001-2004 vitz compressor cost 10 k kabli
    Sent from my GT-I9105 using PW Forums mobile app
    Asad_B's Avatar
    Sep 2007
    Sargodha
    27
    1,943
    2 Post(s)
    dont repair it.go for original vitz compressor.
    Relatives Who Don't Wish Me On My Birthday,............Have No Right To Contact Me On My Result Day
    Site Banned Follow
    aussie112's Avatar
    May 2008
    Baku
    33
    20
    Is your Vitz with a 1.0 litre engine or the 1.33 litre engine? There are two different types of AC compressors. If you can look at the actual compressor and tell me which Denso compressor you have, I might have a solution for you. Is your AC working fine otherwise? One thing you can do to check if your R134a refrigerant gas is full, is to check the H pressure sight glass, which is located next to H plastic cap on the left side of the engine (when standing right in front of the car). If the glass has bubbles in it, then the gas charge is low. If there are bubbles, there is a high chance that there was less refrigerant gas in the system, that has caused the AC compressor to overheat and you will need to replace the compressor.
    vickybhai's Avatar
    Aug 2005
    26
    2,448
    38 Post(s)
    My passo is also giving same type of problem...the A/C compressor pulley is not running smoothly...
    1)Suzuki Mehran has changed its shape 2)Fake parts drive me nuts
    3)https://www.facebook.com/RoyaleEM
    Newbie Follow
    Khawab's Avatar
    Sep 2008
    Hari pur
    27
    I m experiencing the same problem with my 1.3L 2NZ-FE Vitz 2006 model, AC compressor gives Tick tick sound and AC is not working at all, i made it checked through some machanics one said that compressor's bearing/pully is making that sound but other machanic said it's compressor needs to be changed and genunie compressor costs around 24k. He sujjested to use corrolla's AC compressor, will cost 7-9k or with kabli around 11-13k but i willing to stick with the orignal Vitz's.
    Please Advice.
    alikhan7's Avatar
    Mar 2005
    Multan
    33
    744
    6 Post(s)
    Permanent solution for your problem is genuine compressor which costs around 24k
    Thanks
