Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree5Likes
Thread: Vitz 2003 vibration
    ibadaslam872's Avatar
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Default Vitz 2003 vibration
    Salam PW's,
    My Vitz 2003 vibrates b/w the speed of 30-45km/h. It only vibrates at thing speed when accelerating. It vibrates in all the gears (as in, even when accelerating fastly in the 1st gear or casually in the second). It only vibrates at this speed. What could be the issue? Thanks.
    Sent from my GT-S5660 using PW Forums mobile app
    Under the Coconut tree
    ahmedwasiq's Avatar
    Nov 2007
    Rawalpindi
    31
    396
    6 Post(s)
    You need to replace the axel (Goda) of that specific side
    Mechanic insist to repair it but its simply useless
    Just replace it n get free
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by ahmedwasiq View Post
    thanks for the prompt reply. Any idea of how much it'd cost?
    ahmedwasiq's Avatar
    Nov 2007
    Rawalpindi
    31
    396
    6 Post(s)
    Here in Rawalpindi i have paid 2500 for goda and 500 labor
    waleed911's Avatar
    Sep 2011
    486
    16 Post(s)
    Check Engine mounts, they may be loose... Check alignment... See if the wheels are balanced...
    The axle can only be a problem when turning (And that too when it makes tuk tuk noises)...
    Driving is not about going from point A to point B, it is the point...
    ahmedwasiq's Avatar
    Nov 2007
    Rawalpindi
    31
    396
    6 Post(s)
    Boss tuk tuk sound comes when the turning axelz worn out
    This is the issue with running axelz
    These are the one which are connected with gear box
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by waleed911 View Post
    My car makes a minor tick tick noise when turning left. The sound car only be heard from the outside.
    I had the allignment done when I got new tires. The engine mounts are alright aswell.
    Thanks
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,958
    32 Post(s)
    Quote Originally Posted by LIANARULES View Post
    Thanks
    If you car is making tuk,tuk noise while turning that would be a sign of bad cv joints
    get your car's CV joints(axles) replaced
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by Fahad.Ayub View Post
    of you car is making tuk,tuk noise while turning that would be a sign of bad cv joints
    When my liana's CV joints went bad, the sound could be heard inside. But here, we only hear a 'tick tick' from the outside.
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,958
    32 Post(s)
    okay lets wait for other experts to reply
    btw did you check the engine mounts ? how ?
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,958
    32 Post(s)
  12. #12
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Bro, the car went for a check up a few weeks ago. Tuning, oil change, throttle body and all. I told him about this issue, he checked the engine mount and asked me to get the car alligned as there was an issue with his machine. I haven't been able to visit him after that.
  13. #13
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    most likely the axle need repair / replacement. when car is lifted also check for front upper shock mounts ( insulators as in pictures)
    Vitz 2003 vibration -1319762Vitz 2003 vibration -1319763
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  14. #14
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    it can be due unbalanced wheel can cause wobbling plus check mount and rubber bushes its not a sign of bad axle will make noise if something is wrong with them do check the ball joint play they might be loose can be temporary pressed it will work for 2 3 months
  15. #15
    silent833's Avatar
    Jan 2011
    151
    ckeck ur iner excel ...same happng wit my platz prob will b solved after change iner excel
  16. #16
    wawaguls's Avatar
    Aug 2013
    Default usman
    change the axle that fits in the gear not the cv joint. u will feel vibration only when u acccelerate and feel smooth if you put ur car suddenly in N
  17. #17
    wawaguls's Avatar
    Aug 2013
    silent833 is right. change inner axle
  18. #18
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Quote Originally Posted by silent833 View Post
    Quote Originally Posted by wawaguls View Post
    I'm having exams at the moment.
    I'm going to start working on my vitz after the 24th. I had it checked though. The CV joints and the inner axle need to be replaced.
  19. #19
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    Price estimates anyone? (CV joints and the gear axle)
  20. #20
    Feb 2009
    18
    6,107
    5
    49 Post(s)
    My car need's new CV Joints (Goday) and a new gear axle (the axle which goes from the transmission)
    Now the car's Goday only make noise when turning sharply or taking a U turn. Isn't it repairable? My friend had his CL9's Goday repaired and they don't make noise as yet. He drives like an @$$ aswell, and yet they're fine till now.
    I have to options:
    1) Kabuli parts. With labour, cost 14000
    2) Chinese 'Goday' with kabuli Gear axle. cost 9000 including labour
    3) have everything repaired. 3-4k
    What should I opt for?
