Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Like Tree8Likes
Thread: Vitz Ground Clearance Issue - Should I change tyres?
    Adnan959's Avatar
    Jul 2009
    46
    57
    Exclamation Vitz Ground Clearance Issue - Should I change tyres?
    Hello all,
    I purchased a Vitz 2010 a few days ago, immediately I noticed there's a ground clearance issue with the car where the car hits from the bottom with almost every speed breaker. I am concerned if some of this is due to my tyre size that came with the car.
    Right now the car has 165/70 R14. Should I consider upgrading do a different size if it would raise the height of the car a little bit?
    Your advice would be appreciated!
    Thanks!
    talhabinomar's Avatar
    May 2011
    26
    2,470
    38 Post(s)
    I have Vitz 2009 model. I had the same problem. I went for putting spacer in the rear shock. It was raise up to 3 inches and my life was easy. Total expense was about rs. 3000. Way less than going for the 15 inches rims and tyres. The tyres are stock.
    Adnan959's Avatar
    Jul 2009
    46
    57
    Thanks for the response. Did that issue harden your suspension or make the car uneven on faster speeds? Or bounce on uneven roads?
    hamza_xeg's Avatar
    Aug 2009
    Abbotabad
    20
    8,788
    94 Post(s)
    8 Thread(s)
    spacer's make the car look hideous, believe me. upgrade the tyres instead, go for a somewhat bigger size.
    The men are back. @TGT.
    civic7's Avatar
    Sep 2011
    Other
    544
    20 Post(s)
    Change tyres to 185/70/14 along with 1" spacer on rear.
    Sent from my GT-I9192 using PW Forums mobile app
    ?Everyone should be respected as an individual, but no one idolized.?
    May 2011
    26
    2,470
    38 Post(s)
    Not such issues. Good on Road. Advantage is no more bumping on speed breakers with even four adult at the back
    Adnan959's Avatar
    Jul 2009
    46
    57
    Quote Originally Posted by civic7 View Post
    Thanks, but how will adding thicker tyres help when profile is the same? I'm still a newbie at this so don't mind me asking. Adding 1" spacer sounds resonable I think, do you recommend a type? Alumunium Vs Rubber?
    Quote Originally Posted by hamza_xeg View Post
    I agree, i've added spacers in the past in my Alto, it ruins everything. What size of tyres would you recommend?
    Quote Originally Posted by talhabinomar View Post
    Thanks!
    hamza_xeg's Avatar
    Aug 2009
    Abbotabad
    20
    8,788
    94 Post(s)
    8 Thread(s)
    Quote Originally Posted by Adnan959 View Post
    yes and the stability is also ruined, I had the same problem but then I changed the wheels to 15's, you should do the same. the car will hit extra high jumps only, that too can be avoided by going over them in a zig-zag fashion.
    Tabish1's Avatar
    Feb 2007
    3,068
    24 Post(s)
    Spacer will Ruin your Suspension...
    Pakistan <3
    Docjunaid's Avatar
    Mar 2012
    Sadiqabad
    2,046
    48 Post(s)
    2 Thread(s)
    15 size Rims
    195R15 tyres
    Keep tyre pressure 28+
    ive been using this set up for almost 2 years now
    No spacer needed
    Even with 4 person in car ground clearance is good
    Sent from my 4S using Tapatalk
    Glory Glory Manchester United
    Hammad00007's Avatar
    Feb 2013
    23
    135
    Same problem with my Vitz 2002 it hits every bump with 4 people any suggestions?
  12. #12
    Docjunaid's Avatar
    Mar 2012
    Sadiqabad
    2,046
    48 Post(s)
    2 Thread(s)
    Bro's if im not wrong standard size recommended for vitz is 165R14
    Increasing the tyre and rims size helps a lot ground clearance improves
    Spacers = stupid ugly car IMO
    This is my set up
    Totally happy with it
    No bumps No worries
    Awesome Grip as well
    MashaAllah
  13. #13
    Adnan959's Avatar
    Jul 2009
    46
    57
    Quote Originally Posted by Docjunaid View Post
    15 size Rims
    195R15 tyres
    No spacer needed
    What about your mileage? I heard it reduces to 11 from 15 if you put tyres that thick, is that the case for you too?
  14. #14
    Docjunaid's Avatar
    Mar 2012
    Sadiqabad
    2,046
    48 Post(s)
    2 Thread(s)
    @Adnan959
    I get constant 13-14 with ac in local routes
    On long routes depending upon driving style 15-16.5 km/l
    Im more than happy with mileage as im a daily runner of abt 60+ km
    If mileage wasnt good i would hv sold this vitz by now
    U can go for 185 tyre size with 15"
  15. #15
    khm42747's Avatar
    Jan 2013
    1,340
    43 Post(s)
    2 Thread(s)
    15 size Rims
    195R15 tyres
    No spacer needed
    Brother the size ur telling is not for car as it is a commercial size used in wagons , high roofs and many more but not in cars.
    Sent from my GT-N7100 using PW Forums mobile app
    Don't Compromise Because So Much Is Riding On Your TYRES.So Be SAFE and Choose Wisely.
  16. #16
    khm42747's Avatar
    Jan 2013
    1,340
    43 Post(s)
    2 Thread(s)
    For vitz in 15 inch rims 185 65 R15 is the size which is normally used.
  17. #17
    Docjunaid's Avatar
    Mar 2012
    Sadiqabad
    2,046
    48 Post(s)
    2 Thread(s)
    Quote Originally Posted by khm42747 View Post
    Bro ppl use tyre size what they like
    I already mentioned 185 15"
    In my previous post
    Btw my setup is 195/60/R15
    Working beautifully for me Name:  ImageUploadedByTapatalk1387284793.892936.jpg
  18. #18
    issamkhan1's Avatar
    Jul 2013
    28
    Salam all;
    Hey was reading a few posts as i am currently having a few problems with my vitz which i bought just a month back. First there is a lot of ground clearence issues and i want to avoid spacers so which size of tyres or rims should i go for. Secondly my vitz economy is round about 12 km/L how to improve that. Third and foremost its engine is rather noisy.
    Some guidance on such paticular issues would be highly appreciated.
  19. 29-12-2013, 09:25 PM
    PakWheeler
  20. #19
    issamkhan1's Avatar
    Jul 2013
    28
    Guyz,
    Need sone help regarding ground clearance. One of the Toyota dealers suggested to increase the spring size from 6 to 9 inches
    Support sought
  21. #20
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by issamkhan1 View Post
    Guyz,
    Support sought
    your dealer is smoking weed?
