Results 1 to 11 of 11
Thread: Toyota vitz gearbox
    6750's Avatar
    Dec 2013
    9
    Default Toyota vitz gearbox
    Salam
    My vitz's has lost its speed, whenever i put it to full throtle, the engine makes more sound but the power isnt being transferred to the tires, my mechanic says that gear box is shot and that i need to replace it,he said something about sliping clutches
    Please suggest what to do, and how much would the new gear box cost?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    what year model is your car? the old one has shifting automatic while the newer one is cvt.
    6750's Avatar
    Dec 2013
    9
    I have toyota vitz 2007
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,578
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    in the meantime read this thread
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    Quote Originally Posted by 6750 View Post
    07 is cvt, and what you describe is normal as it cannot shift, if you boot the pedal to the floor the engine rpm will stay 200 rpm below redline and the transmission will pull the car at its maximum capacity.
    Word of advice - replace your mechanic
    StrikerX's Avatar
    May 2010
    1,239
    61 Post(s)
    2 Thread(s)
    What are the common symptoms of a Toyota CVT failing? and also as compared to normal AT's you mentioned these CVT boxes run very hot. So, is there any sort of care one should take while driving a CVT tranny car as compared to normal AT?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    Dont overwork the gearbox - meaning drive it gently
    If you feel shudder - your torque convertor lock up is about to go on permanent vacation ($$$)
    Rough shuttling (noise) is preparing for disaster
    It would be nice to install an additional cooler but you cannot in a toyota as coolant goes to the gearbox rather than CVTF going to the radiator.
    6750's Avatar
    Dec 2013
    9
    Xulficar even when i dont go to full throtle, the speed is not moving up than 60*,and sport gear (s) is also not working!, my friend vitz same model, is faster than mine, like a lot Faster
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    do a full test with a toyota intellitester to see whats going on.. sounds like the trans is in limp mode.
    6750's Avatar
    Dec 2013
    9
    Xulficar
    Limp mode?
    Newbie Follow
    click4mee's Avatar
    Oct 2016
    Default Gearbox problem
    Sir i have vitz 2010 model engine 1.0cc but now i have changed my car engine with 1.3cc my question is there a different between 1.0 gear box and 1.3 gearbox???
