Results 1 to 4 of 4
Thread: Code reader for Vitz
    thbaig's Avatar
    Sep 2005
    38
    97
    3 Post(s)
    Default Code reader for Vitz
    Hi,
    I have vitz 2007 . I am in plan to purchase its scanner, just for my own usage to see internal of ECU.. I have seen some ads on olx about these scanners, it range from 1800-2800 PKR (elm327 car code reader bluetooth,usb,and wifi - Islamabad - Car Parts - rawalpindi) .
    They saying it is ObdII compliant and will work on all japanes models.
    I would like to know will this work for vitz 2007? also have someone experience with this model ?
    talhabinomar's Avatar
    May 2011
    26
    2,472
    38 Post(s)
    First ask any experienced mechanic to check which scanner fits it.
    mohammadsahel's Avatar
    Feb 2014
    49
    5 Post(s)
    I don't think it would work on jdm.
    Sent from my HUAWEI P6-U06 using Tapatalk
    VGate ELM327, Launch Creader 6+ / 7+ / 8, X431 V, VDM, Autel DS708 / MD802, Honda HDS, Toyota IT2, Digiprog 3 Odometer reverser. Anyone needs help or guidance on these, please PM.
    Feb 2014
    49
    5 Post(s)
    If your vitz is the US or European version which is called Yaris, it will work.
    If it's the Japanese model, it won't. Because the Japanese models use the M-OBD system. Not OBD II.
