hi PWS
I am having a brake problem in my vitz when i press brake paddle at half level it gives a 'TAK' sound and at the second immediate press there is no sound but after 2 to 3 minutes it again gives the same sound.
Suggestions Please..
Thank you
get brakes inpected (and serviced if neccesary). Flush the brake fluid and bleed air out.
It could be related to a weak or loose suspension part,get it checked properly.
Is that a A.B.S sound ?
It's the Bush which is attached to the 'Chimta'. Get it checked. The bush is probably broken.
Sent from my GT-S5660 using PW Forums mobile app
thankx buddy..BTW what are the requirements for servicing brakes?
Thanks bddy.
no its not ABS sound..brake is working properly but that tak sound is irritating
do get engine mountings checked
