Results 1 to 15 of 15
Like Tree20Likes
  • 1 Post By zeeshan368
  • 2 Post By whiteangel
  • 1 Post By cracked
  • 6 Post By Xulfiqar
  • 1 Post By Nabeel009
  • 3 Post By Xulfiqar
Thread: Car Vitz flag type indication
    smarthief's Avatar
    Aug 2011
    109
    Default Car Vitz flag type indication
    An indication appearing on speedmeter. That indication which on left corner. Snaps are upload for that sign. Plz tell me about that. Thankss.
    Sent from my MT27i using PW Forums mobile app
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    Low coolant temperature
    Sent from my GT-I9100 using PW Forums mobile app
    whiteangel's Avatar
    Nov 2005
    2,243
    9
    65 Post(s)
    That indicates coolant temperature. When you start the car in the morning, it will be blue indicating that temperature below normal. When the engine warms and coolant reaches optimum temperature the light will go out. If it turns red, it means the engine is overheating.
    Never argue with an idiot, they drag you down to their level and beat you with experience.
    cracked's Avatar
    Mar 2009
    Rawalpindi
    28
    2,963
    35 Post(s)
    its coolant temp light.when you start the car,it will be pm till temperature of coolant reaches specific level, and then IT SHOULD GO OFF.if it dosent,something is wrong with cooling system,either low on coolant or car overheating
    REAL men drive manual cars!
    smarthief's Avatar
    Aug 2011
    109
    Quote Originally Posted by whiteangel View Post
    Thanks for reply. Well at its coming not with blue its appearing like green at startup.
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    Is it going off after the engine warms up like 3 4 minutes?
    supraman2jz's Avatar
    Jun 2008
    33
    2,700
    76 Post(s)
    Has an electrician tempered with the car recently? Check if your fan is auto and not direct, and check if the thermostat is working as it should.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    really????????????? FLAG?
    this symbol is the standard for temperature gauge since the last 70 years. Every car of the world has this either in the form of a temperature gauge or the idiot light like this.
    Its actually a thermometer dipped in liquid - symbol
    Nabeel009's Avatar
    May 2009
    Rawalpindi
    23
    158
    bhai meri mehran me to nae hai
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by Nabeel009 View Post
    Car Vitz flag type indication -1339773
    See the area above the needle pivot. This is a mehran meter gauge.
    smarthief's Avatar
    Aug 2011
    109
    sometimes mind make similar shapes and name ... to I named that symbol.... I apologize if I mentioned any wrong thing...
  12. #12
    smarthief's Avatar
    Aug 2011
    109
    Quote Originally Posted by zeeshan368 View Post
    yes it go off after some time .... I got why this symbol after reading all posts .... because here in Quetta temperature is too cold ... to low coolant symbol should be appear ....
  13. #13
    Khurram26's Avatar
    Dec 2006
    38
    276
    13 Post(s)
    Quetta=Cold
    Engine=Cold
    Flag=Green
    Drive Slow
    Quetta=Cold
    Engine=Warm
    Flag=No Flag
    Drive As You Wish
    Quetta=Cold
    Engine=Hot
    Flag=Red
    STOP! Engine Overheating
    Bhai, this is the entire philosophy for you in simple words.
    Sent from my SM-N900 using PW Forums mobile app
  14. #14
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    in this car the red warning means = engine tamaam howa
  15. #15
    Newbie Follow
    sfarheenkazmi's Avatar
    Sep 2016
    Default Trip A indication shown in meter
    Can you please help me to identify what does Trip A indication means in vitz 2012 1000cc car. All of sudden this wording shown in meter.
